kevjay
17 Nis 2019
[QUOTE = "yokoono, inlägg: 87207, medlem: 6137"]
För kevjay
Jag har lagt upp (post 6089) en programvara för VES430QNDL-2D-U11. För VES430QNEL-2D-U01 har jag inte. Försök. Kan gå. Framgång.
[/ QUOTE]
Did not work. How long is the tv supposed to flash/how long does it usually take for it to finish and start?
yokoono Çevrimdışı
1. 5-10 minutes.
OR
2. Strobe light is no longer flashing
OR
3. Reboot itself.
OR
4. The image appears
Or drink a beer
:sirit
kevjay
17 Nis 2019
1. 5-10 minutes.
OR
OR
3. Reboot itself.
OR
Or drink a beer
:sirit
Haha! Just have to be patient, after 10 min, if it still doesn't work is there some kind of recovery file? Don't want to do anything before consulting.
kevjay
17 Nis 2019
[QUOTE = "yokoono, inlägg: 87216, medlem: 6137"]
Är TV nu funktionell?
[/ QUOTE]
Not booting up no.
yokoono Çevrimdışı
The boot sequence is damaged. There is no alternative. Try.
It is possible to start but with a turnaround image.
kevjay
17 Nis 2019
[QUOTE = "yokoono, inlägg: 87223, medlem: 6137"]
Upp och ner.
[/ QUOTE]
Ok, thanks, nothing to do then :(
yokoono Çevrimdışı
Normally the stb light flashes about once per second (aprox.). The update is blinking much faster.
Does not flash quickly = does not update
yokoono Çevrimdışı
Expect more time. Drink a beer. I hope you follow the procedure (with the OK key pressed).
yokoono Çevrimdışı
Last chance. I have nothing for your TV. If not work change .pkg with .upg. Unzip/ 1 file.
J Çevrimdışı
javier_sonar
23 Nis 2019
12
60
hola yoko
gracias por tu ayuda
La televisión era para un cliente.
No pude voltear la imagen.
Te vi mandarme software, pero no pude.
El cliente quedó satisfecho con la imagen.
De todos modos, gracias.
Todavía te estoy molestando otro día.
gracias
