- 20 Mar 2019
- 3,420
- 74
Try
Giriş yap veya üye ol.
Try
Copying the profile to the TV is done other than the software update. With USB Option input. Do you know the procedure?
Does not work, do you have an older firmware of the firmware you sent me? When not, I don' t want to steal more time of you, then it doesn' t work and good is.Try it like this:
1. Put a blank folder called downloadprofile.mb110 on the stick
2. Copy the folder called PROFILE on the stick (you can find it in the profile I gave you). You will have 2 folders: downloadprofile.mb110 (empty) and PROFILE (with my profile).
3. Turn on the TV and insert the stick into the USB. If you are asked to dry the stick, choose NO.
4. Type MENU and 4725
5. Scroll down to USB Operations and type OK.
6. Wait 20-30 seconds and exit MS (back key)
7. Turn off the TV from the remote control. The stb LED will blink fast. When it stops blinking it is ready.
8. Remove the stick and turn on the TV.
1- zip ten çıkartDoes not work, do you have an older firmware of the firmware you sent me? When not, I don' t want to steal more time of you, then it doesn' t work and good is.
I have no access to the menu, because the screen freezes after I install the right firmware, I can't do anything, the TV don' t react to commands. And the profile I can' t install to the wrong firmware, because the TV don' t recognize the profile from another panel, and about my panel I find nothing in www. The panel is 43_vesund12_2D.
Because the problem was not solved you can rewrite the flash memory. But you need a programmer.I have no access to the menu, because the screen freezes after I install the right firmware, I can't do anything, the TV don' t react to commands. And the profile I can' t install to the wrong firmware, because the TV don' t recognize the profile from another panel, and about my panel I find nothing in www. The panel is 43_vesund12_2D.
