sn:8280829 901447
Yükleme anlatım full : tıklayınız
sn:8280829 901447
For you. Main 17MB110 and panel VES430UNDL-2D-N12The TV had resetted independently, after I received a new firmware from Telefunken, I can not perform a first installation more, because the TV is frozen on the home screen and no longer responds, now I need a firmware that I can play.
I hope the translation program translates understandable, I really need a suitable firmware, even an older one.
benim takıldığım nokta uyumlu yazılım böyle yapması şaşırttı, ve test ettiğim bir yazılımdıyönergeleri aynen izledim fakat yüklendiğine dair bir emare yok maalesef
Teşekkür ederim görüntü geldi tv tamamen düzeldi.
Thank you, unfortunately I can not install the firmware, the same problem as with the firmware that I got from Telefunken, the start screen freezes and does not respond to commands, see pictures:For you. Main 17MB110 and panel VES430UNDL-2D-N12
If you do not want with the original software it is possible to have something in memory nand: corrupt software, nand with bads.
If I give you a profile saved from the functional TV you can distinguish from the image how to install it?
If I give you a spi bin (flash memory) do you have a programmer for rewriting?
Let's try that.
I don' t come into the menu, I have only the startscreen I posted aboveIf you enter SM (menu + 4725) you can distinguish where USB Operations is ?.
I can not get into the menu, I just have the start screen of the initial installation that I posted above, I can not do anything, change or confirm any language, nothing.
The picture of the menu is before the Problems began, before I got the new firmware from Telefunken, now I don' t come into the menu anymore.And the picture above when you did it ?.
To install the profile you must enter the MS. USB Operation is required. If USB Operation cannot be accessed, the profile cannot be installed.
Can you at least add him in this state? This is how MS can be accessed?
With the "correct" firmware from Telefunken (and you) I have no access, only the frozen screen, which no react, with the wrong firmware from my other Telefunken TV (D40F287N4CW) I have access and could import a profile, BUT there(then I have the destroyed picture, maybe you could send me the profile "saved from the functional TV" and I try my luck.
