In France
cadkey' Alıntı:
your television's software version 2.43.2.0. the current top software version is 2.43.2.0. I do not understand what the problem is?
cadkey' Alıntı:
If you want to format the full software and can be upgraded again, but you need the serial number. Example of serial number SN: 7776655 400300
I read that with version 2.43.2.0 the tv was hdr, but I have no HDR.
cadkey' Alıntı:
hdr active information came from some members but there is no technical explanation that this is 100% correct. We can check your serial number for HDR support. :ok:
Where can I found my serial number please?
cadkey' Alıntı:
you can see the TV under the barcode in the middle of the back. or box, but you've probably got a box
Thank you, yes on my box:
SN 7848027 700056
cadkey' Alıntı:
SN 7848027 700056
your television production code is V10108799 and there is no hdr support in this production unfortunately
Thank you for your help and your patience. It was not easy for me to understand the Turkish language which is very badly translated with google
What is the television production code?
What is it for?
cadkey' Alıntı:
What is it for?
I use google translate because I do not speak english. production code is the code that determines the properties of the television. This code decides which properties will be available in production.
Ok, and latest question please
In my menu, I can't modify led backlight intensity,
the menu is grayed out, not accessible. is this normal?
cadkey' Alıntı:
if you set the economy mode to automatic, the gray area (the passive area) is active and you can adjust the dimming.
Ok, I did not think about that, it makes sense.
Thank you very much for your help, I know better now my tv and its possibilities.
Thanks again
