yırtık etiketli olan paneli mb140 anakarta takacakmış
OK. I'm waiting for them to tell me what the problem is with the TV. If there's no picture, they can't use the panel profile. It can be done without seeing the picture, but I don't think they'll understand.
Merhaba 17mb82-2 yazılım lazım yardımcı olursanız sevinirim.
Model : 24VH3050 24" USB LED TV
Panel profile for 17MB140 panel VES315WNDH-2D-N22 ????
Resimde ne sorun var? MENU 4725 yazın ve resmi buraya koyun.
back light var resim yok
seg markadan vestele geçilcek sanırım dönüşüm yazılımıda gerekecek anakart üzerinden flashları aktarmayı denedim ama çözüm olmadı.
vestelde anakart arızası var. seg de panel arızası ikisinde bir tane yapmaya çalışıyorum
I have this profile: 17MB140 panel VES315WNDH-2D-N21
I have this full software: 17MB140 panel VES315WNDH-2D-N22 Telefunken
17MB140 panel VES315WNDH-2D-N22 Telefunken profili daha uygun gözüküyor. Marka vestel yerine telefunken görünücek sanırım problem olmaz.
dönüşüm yazılımıda gerekli olucak mı?
Full software. Yazılım yüklemede sorumluluk tamamen sizdedir.
[QUOTE = "Ado, post: 7751, member: 363"] Dear Friends;
First of all, even though we know that there is no longer any need to talk about the risks of software installation, I would like to start by reminding you that the software installation is a complete adventure with the idea of aba I wonder what will happen? Düşün.
Especially for MB9X series users, and especially for FAZ2 users, this topic is a complete adventure, so please do not install software on the grounds of "ACABA" if you do not have a problem. I would like to remind you about this situation in advance, such as system crash, service, motherboard replacement, high service cost.
This topic only shares the original core software.
Please read the important warning section at the end of the article.
I do not provide information about what has changed in the upgraded software, and these are expressed in the forum by our friends as user experience.
Please note that the issuer of the software itself may cause problems with the product under the warranty conditions.
When installing the core software X for some reason you will need full software to install the TV.
Full software is large in terms of size and because it is special for every TV, we do not want to send a full software to every friend who asked for it in time.
Authorized services already provide free service to all products that fail, but please note that they have the hardware to detect the replacement software.
All of these warnings are to protect both your security and your rights, but also to prevent unnecessary failure of your product.
MB82 recovery software can be used for Vestel TV Malfunctions. Kernel softwares are not a factor in MOSCOPE TV situations, but are a factor in software-based bug situations and product performance improvements.
After all this information, how to install the software.
Before and after the software installation, please do not forget to perform a version check by entering the service menu with MENU 4725.
All softwares in this area can be downloaded from USB. In this sense, it is important to have a high data rate of the USB, because in some cases, ira Image shows the video but I cannot install the software in. I would like to inform you that Sandisk hasn't had much negative return in memory.
There are 2 methods to install software (other than the pro methods installed with Debug cards)
A- FULL software installation method
The order in this Method is as follows
1- Software that is suitable for free memory formatted as FAT 32 is placed as CLASSless
2- TV plug is pulled
3- Memory is attached to the TV
4- Press and hold the OK button of the remote control and insert the TV plug
5- When the STBY light starts to flash fast, press the OK button.
TV will be turned on in two minutes.
B- CORE software installation method:
1- Appropriate software is inserted into free memory formatted as FAT32
2- Connect to USB TV
3- MENU 1505 is encoded and the answer ır YES ır is answered YES
In two minutes the TV will open itself by completing operations.
FULL software is loaded only with the FULL method but the ROW softwares do not have any downloadable damage by either method [sm = ok.gif]
The following software is the most current official software possible. For more detailed installation instructions, please visit
for information and control of VESTEL [sm = ok.gif]
17MB82 1.35
[Hidden content]
17MB82 1.37
[Hidden content]
17MB82 RECOVERY
[Hidden content]
17mb90_mb91r1r2_mb92r3_mb95_mb95s_mb95m_faz3_v366y
[Hidden content]
17MB91 3.3.8.c Stable version
[Hidden content]
[Hidden content]
17mb91r3_mb92r4_mb96_faz3_v376n
[Hidden content]
17mb96_3.7.6.s
[Hidden content]
17MB97_98_0.45.23.32
[Hidden content]
17MB97-98 0.45.23.39
[Hidden content]
17MB100-34.23
[Hidden content]
17MB100_34.25
[Hidden content]
17MB100 2.7.0.0.
[Hidden content]
17MB110 2.22.0.0
[Hidden content]
17MB110 2.32.0.0
[Hidden content]
17MB110_2.24.1.0_FBTV
[Hidden content]
17MB110 2.35.15.0
[Hidden content]
17MB110 2.35.40
[Hidden content]
17MB110S 3.16.6.0
[Hidden content]
17MB110S 3.16.12.0
[Hidden content]
17MB110S 3.26.6.0
[Hidden content]
17MB120-2.29.6.0
[Hidden content]
17MB120-2.29.11
[Hidden content]
17MB120-2.36.0
[Hidden content]
17MB120-2.40.2.0
[Hidden content]
17MB120-2.40.6.0
[Hidden content]
17MB120-2.43.2.0
[Hidden content]
17MB120 2.45.70
[Hidden content]
17MB120 2.45.101
[Hidden content]
17MB120 2.45.12.1 NETFLIX
[Hidden content]
17.12.2016 (23.05.2018)
[Hidden content]
17MB130 3.19.2.0 (NONCONNECTED)
[Hidden content]
17MB130 3.19.8.0 (NONCONNECTED)
[Hidden content]
17MB130 3.19.11.0 NONCONNECTED
[Hidden content]
MB130-3.3.7.3.0 (CONNECTED)
[Hidden content]
17MB130 3.4.4.6.0 (CONNECTED)
[Hidden content]
17MB130 3.4.7.1.1.0 (CONNECTED)
[Hidden content]
17MB130 CONNECTED 3.62.4.0 Yotube, Netflix Çözüm içerir
[Gizli içerik]
17MB130 3.62.7.0
[Hidden content]
17MB130 3.62.13.0
[Hidden content]
17MB130 3.62.24
[Hidden content]
17MB130 3.62.29 CARBON
[Hidden content]
17MB130 3.62.29 TITANIUM
[Hidden content]
17MB130 3.62.30 CARBON
[Hidden content]
17MB130 3.62.30 TITANIUM
[Hidden content]
17MB140 CARBON menu
[Hidden content]
17MB140 TITANIUM Menu
[Hidden content]
17MB140 1.38.100
[Hidden content]
17MB211 0.49.10
17MB211 0.56.1.0
[Hidden content]
17MB211 0.59.2.0
[Hidden content]
IMPORTANT WARNING;
The TV software X may crash for some reason, the responsibility of the crashed system belongs to the installer. In the Forum, this information is completely shared with the purpose of SUPPORT and HELP, so I would like to remind you that you should not hold us responsible for any problems.
There is a high quality sharing of information in the forum about possible problems, so it is recommended that you take some advantage of this information instead of attempting to install software with 2 lines of writing.
You can also use the operating system for your installation.
Full software and core software.
Please note that the invisible article cannot be used in the article. I'm going to be able to find out what the problem will be. of [/ QUOTE]
[QUOTE = "Ado, post: 7751, member: 363"] [/ QUOTE]
like!
thank you
Merhaba, Firmware MB120 içeriğini modifiye yapabilir miyiz? Örneğin Netfiix ve YouTube sürümünü güncelleme gibi. Her yerde aradım ama bulamadım bu konu hakkında bilgi. Şuanda sorunsuz çalışıyor ama yinede yeni sürüm kurmak istiyorum. Yardım ve önerilerinizi bekliyorum
Λογισμικό,
Uygulama sürümü güncelleme yok
Her iki anakart mb140 ise çalışan anakart hangi televizyona takılacaksa o televizyonun arka kapak etiketi resmini buraya ekleyin. Anakart üzerinde oynama yapmayın.
