Önemli Vestel - Hi-Level - Nexon - Seg - Telefunken Tv. Yazılım Modlama [ilk Mesaj Güncel]
digiulama Çevrimdışı
digiulama
5 Nis 2018
882
43
düzenleyebilirsen onları değilde son versiyonu yap o biraz eski powervu yeni keyler çalışmıyor onda thor uydusunda belgesel için mükemmel
2018/12/19 01:38:52 00000000 s (main) Host name = localhost
2018/12/19 01:38:52 00000000 s (main) Release = 3.4.67_s40
2018/12/19 01:38:52 00000000 s (main) Version = #1 Tue Feb 2 13:53:05 KST 2016
2018/12/19 01:38:52 00000000 s (main) Machine = armv7l
2018/12/19 01:38:52 00000000 s (main) creating pidfile /mnt/sdcard/Android/data/com.android.oscam/tmp/oscam.pid with pid 30102
2018/12/19 01:38:52 00000000 s (emu) OSCam-Emu version 765
2018/12/19 01:38:52 00000000 s (config) userdb reloaded: 2 accounts loaded, 0 expired, 1 disabled
2018/12/19 01:38:52 00000000 s (main) signal handling initialized
2018/12/19 01:38:52 00000000 s (reader) server_1 [cccam] creating thread for device cccamfree-kanasa.com
2018/12/19 01:38:52 00000000 s (reader) softcam [emu] creating thread for device emulator
2018/12/19 01:38:52 00000000 s (stat) loadbalancer: could not open /mnt/sdcard/Android/data/com.android.oscam/tmp/stat for reading (errno=2 No such file or directory)
2018/12/19 01:38:52 00000000 s (main) waiting for local card init
2018/12/19 01:38:52 1149CD58 r (emu) Stream key delayer initialized
2018/12/19 01:38:52 1149CD58 r (emu) Stream relay server initialized
2018/12/19 01:38:52 1149CD58 r (reader) softcam [emu] Reader initialized (device=emulator, detect=cd, mhz=357, cardmhz=357)
2018/12/19 01:38:52 00000000 (emu) INFO: FFDecsa parallel mode = 32
2018/12/19 01:38:52 4DA98377 p (reader) cccamfree-kanasa.com: resolved ip=173.249.43.66
2018/12/19 01:38:52 4DA98377 p (reader) server_1 [cccam] connecting to cccamfree-kanasa.com:9900
2018/12/19 01:38:52 1149CD58 r (reader) softcam [emu] card detected
2018/12/19 01:38:52 4F890336 h (webif) webif: decompressed 177930 bytes back into 438976 bytes
2018/12/19 01:38:52 4F890336 h (webif) HTTP Server running. ip=0.0.0.0 port=8888
2018/12/19 01:38:52 4DA98377 p (reader) server_1 [cccam] proxy initialized, server cccamfree-kanasa.com:9900
2018/12/19 01:38:53 1149CD58 r (reader) softcam [emu] found card system emu
2018/12/19 01:38:53 1149CD58 r (reader) softcam [emu] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max alloted of 1
2018/12/19 01:38:53 1149CD58 r (emu) Reading key file: /mnt/sdcard/Android/data/com.android.oscam/conf/SoftCam.Key
2018/12/19 01:38:53 1149CD58 r (emu) WARNING: non-hex value in SoftCam.Key at B 11262 :30000 :H
2018/12/19 01:38:53 1149CD58 r (emu) Reading key file: /mnt/sdcard/Android/data/com.android.oscam/conf/ee36.bin
2018/12/19 01:38:53 1149CD58 r (emu) Reading key file: /mnt/sdcard/Android/data/com.android.oscam/conf/ee56.bin
2018/12/19 01:38:53 1149CD58 r (emu) Total keys in memory: W:0 V:7 N:6 I:5 S:0 F:225 P:35 D:46 T:120
2018/12/19 01:38:54 00000000 s (main) init for all local cards done
2018/12/19 01:38:54 00000000 s (emmcache) loading emmcache disabled since no reader is using it!
2018/12/19 01:38:54 00000000 s (emmcache) loading emmstats disabled since no reader is using it!
2018/12/19 01:38:54 00000000 s (anticasc) anti cascading disabled
2018/12/19 01:38:54 52F93896 c (client) plain dvbapi-client granted (anonymous, au=off)
2018/12/19 01:38:54 52F93896 c (dvbapi) dvbapi channelcache loaded from /mnt/sdcard/Android/data/com.android.oscam/conf/oscam.ccache
2018/12/19 01:38:54 52F93896 c (dvbapi) ERROR: Could not detect DVBAPI version
teraspy Çevrimiçi
23,213
65
İşte bana tam olarak anlatman lazım,ki anlıyayım iyice. aslında bir döküman hazırlasan,bir yere upload etsen,mesela,nerelerle oynadın, lib dosyalarını nereye kopyaladın,conf içindeki 3 dosyayı nereye kopyaladın ,gerçi sendeki uydu cihaz android,tv ile farklı ama sonuçta hepsi linux :smile:
EK:
Versiyon dediğin hangi varsiyon gibi yani
digiulama
5 Nis 2018
882
43
1- Öncelikle indirdiğimiz dosyayı zipten çıkarıyoruz. Sonra system/lib klasörüne
atılaması gereken ".so" dosyalarını atıyoruz. Bu 4 dosyayı attıktan sonra
"OsCamManager.apk" ile OsCam Manageri kuruyoruz.
2- Sdcard klasöründeki "installation ve conf" klasörünü ya da "com.android.oscam"
klasörünü doğrudan, "sdcard/andriod/data" (com.android.oscam için) içerisine kopyalıyorız.
"sdcard/andriod/data/com.android.oscam" (installation ve conf için) kopyalanacak yol.
3- Şimdi "OsCam Manageri" çalıştırıyoruz ve gerekli ayarları yapıyoruz.
-Webif==>Enabled, -Autostart on boot==>On, Status bar==>On, -OSCam check==>On, SuperUser check==>On
yaptıktan sonra -Update (OSCam)ı çalıştırıp işlemi tamamlıyoruz.
YÜKLEME bitmiştir.
Şimdi "data/app" içinde Oscam Managere ve "data/data/com.android.oscam/bin" içindeki
"oscam" dosyalarına -755 yapıp cihazı yeniden başlatıyoruz.
Oscam Manageri açıp üst-orta da yer alan çalıştırma butonuyla çalıştırıyoruz.
İsterseniz, "data/app" içindeki "Oscam Manager"i "system/app" içine kopyalayıp data/app
içindekini silip cihazı yeniden başlatarak "oscamı" sistem uygulaması yapabilirsiniz.
Güle güle kullanınız.
Not: SoftCam. k e y ve diğer dosyaları manuel olarak,
sdcard/andriod/data/com.android.oscam/conf içine atınız uygulama otomatik olarak görecektir
teraspy Çevrimiçi
23,213
65
Tamam,en azından elimde veri olsun,çünkü olay kafamda çözüldü ,tv deki program pc ile irtibat kurup çalışacak,doğru mu :smile: tabii şu meşhur dvbapi de çok önemli
teraspy Çevrimiçi
23,213
65
Tamam,kopyaladım ve göz gezdirdim :ok
EK:
Bana yolladığın dosyalar android içini,sakın tv ye deneme.
digiulama
5 Nis 2018
882
43
pc nin amacı köprü bize olanağı dosya alışverişi önemli olan bize tv nin oscam performansı eğer oscam hata verirse yayın kopar oscamı denerken cccam satırı atman gerek
burdan test satırı alki cccamın takılıp takılmadıgını görürsün dvb api hata verir belki oscam durmaz olurmu olur
teraspy Çevrimiçi
23,213
65
Hımm,bu linkte neye dikkat etmeliyim? mesela server status online yazıyor,buraya mı
EK:
Bence tvde kopmaz,çünkü bendeki saatlerce açık kaldı,sorun olsaydı hemen atardı programı, hatta 5 dakika bile kalmazdı :wink:
teraspy Çevrimiçi
23,213
65
baülandıgında böyle görürsün kart sayısı ip nosunu
Aldım resmi , ... valla tohumu toprağa attık :) dediğim gibi %90 çalışıyor,bu kesin ,yani oscam programından bahsediyorum,bu konuya daha önce hiç girmemiştim,hanım" tv bozarsan karışmam" dedi biraz önce,bende 32'' buraya koyarız seyredersin dizileni dedim :haha1
Bu konuda yabancı kaynak çok da bizimkilere soru soruyorsun "orda yazıyo" diyorlar.Bu siteden bahsetmiyorum tabii,şimdi senin sayende elimde iyi bir veri var,tabii sevgili tartar10'nu da unutmamalıyım :) ,tek bağlantı dvbapi kalıyor,sanırım bunu pcye kurduğum programla halledebilirim,şu mavi ekranlı resim olan.bu arada saat 02:30 olmuş
Senin resimlerinde atlanta olanda önünde . (nokta) olan klasörler gizli klasörlerdir,linuxta önüne .(nokta) konulduğunda klasör veya dosya gizlenir,biliyorsundur belki ama senin adında herkes öğrensin madem.
EK:
Artık ben kaçar,gözlerim yoruldu,en son Emre78'e de cevap verdim,iyi geceler,yardımların için teşekkür ederim.
digiulama
5 Nis 2018
882
43
Nokta olan klasörleri farklı bir program var onunla açılıyor onları oynadığında çöküyor :) Herşey receiver kadar basit olsa tv işine girmedim çökerse 600 liralık receiver çöksün elimde cihaz çokta tv yok kalırım ortada tv yi onun için fazla kurcalamıyorum
0 Çevrimdışı
01mrt42
26 Şub 2018
20
Herkese merhaba, TV den ses az geldiği için 2+1 hoparlör taktım ama ses arttırınca tv deki hoparlör artıyor.
2+1 in sesini ayrıca menüden arttırmak gerekiyor. Bu yöntemle bir şeyler yapılabilir mi? MB95 anakart, daha önce PVR açmıştım.
tartar10
8 Kas 2018
209
Sn. teraspy teraspy, oscam'ın çalışması için pc'ye ihtiyaç olmaması lazım. Pc sadece, tv'ye kurulacak olan Oscam için dosyaları yükleme ve düzenlemede kullanılabilir.
teraspy Çevrimiçi
23,213
65
Pvr açtıysan şunu da deneyebilirsin,SWprofilden toolbox ile config kısmındaki AudioDescriptionOutEnabled = TRUE, ve CommVolConrtol =TRUE yap bakalım.
Hımm,bugün mips için derleme yapayım dedim,sinir oldum,sanırım kafam iyice durdu...
Dışarı çıktım,hanımla pazara gittim-geldim,hadi yine deniyeyim dedim ,yok ,bir yerde hata yapıyorum ama nerede,
Böyle bir dosya veya klasör yok dedi iyimi :))
Var halbuki klasör, öndeki ./ sildim ,derledi ama olmadı :) bıraktım bir süreliğine
