<?xml version="1.0" encoding="utf-8"?>
<key_xml>
<fortis-key>
<key value="0x8c73f902" name="KEY_SLEEP" /> <!-- -->
<key value="0x8b74f902" name="KEY_WAKEUP" /> <!-- -->
<key value="0xff00f902" name="KEY_UP" /> <!--key up-->
<key value="0xfe01f902" name="KEY_DOWN" /> <!--key down-->
<key value="0xfd02f902" name="KEY_RIGHT" /> <!--key right-->
<key value="0xfc03f902" name="KEY_LEFT" /> <!--key left -->
<key value="0xe01ff902" name="KEY_ENTER" /> <!--key ok -->
<key value="0xe31cf902" name="KEY_BACK" /> <!--key exit -->
<key value="0xfb04f902" name="KEY_MENU" /> <!-- -->
<key value="0xf50af902" name="KEY_POWER" /> <!-- -->
<key value="0xb14ef902" name="KEY_VOLUMEUP" /> <!-- -->
<key value="0xb04ff902" name="KEY_VOLUMEDOWN" /> <!-- -->
<key value="0xf30cf902" name="KEY_MUTE" /> <!-- -->
<key value="0xee11f902" name="KEY_1" /> <!-- -->
<key value="0xed12f902" name="KEY_2" /> <!-- -->
<key value="0xec13f902" name="KEY_3" /> <!-- -->
<key value="0xeb14f902" name="KEY_4" /> <!-- -->
<key value="0xea15f902" name="KEY_5" /> <!-- -->
<key value="0xe916f902" name="KEY_6" /> <!-- -->
<key value="0xe817f902" name="KEY_7" /> <!-- -->
<key value="0xe718f902" name="KEY_8" /> <!-- -->
<key value="0xe619f902" name="KEY_9" /> <!-- -->
<key value="0xef10f902" name="KEY_0" /> <!-- -->
<key value="0xb44bf902" name="KEY_F1" /> <!-- red -->
<key value="0xb54af902" name="KEY_F2" /> <!-- green -->
<key value="0xb649f902" name="KEY_F3" /> <!-- yellow -->
<key value="0xb748f902" name="KEY_F4" /> <!-- blue -->
<key value="0xa758f902" name="KEY_REWIND" /> <!-- << -->
<key value="0xa35cf902" name="KEY_FORWARD" /> <!-- >> -->
<key value="0xaf50f902" name="KEY_PREVIOUSSONG" /> <!-- |< -->
<key value="0xb34cf902" name="KEY_NEXTSONG" /> <!-- >| -->
<key value="0xab54f902" name="KEY_STOP" /> <!-- -->
<key value="0xf906f902" name="KEY_INFO" /> <!-- -->
<key value="0xf807f902" name="KEY_PLAYPAUSE" /> <!-- -->
<key value="0xbe41f902" name="KEY_FAVORITES" /> <!-- -->
<key value="0xa15ef902" name="KEY_CHANNELUP" /> <!-- -->
<key value="0xa05ff902" name="KEY_CHANNELDOWN" /> <!-- -->
<key value="0xbc43f902" name="KEY_PAGEUP" /> <!-- -->
<key value="0xbb44f902" name="KEY_PAGEDOWN" /> <!-- -->
<key value="0xf609f902" name="KEY_RECALL" /> <!-- -->
<key value="0xaa55f902" name="KEY_PLAY" /> <!-- -->
<key value="0xa956f902" name="KEY_RECORD" /> <!-- -->
<key value="0xbf40f902" name="KEY_PVR" /> <!-- -->
<key value="0xf10ef902" name="KEY_F5" /> <!-- KEY_VFORMAT -->
<key value="0xe11ef902" name="KEY_F6" /> <!-- KEY_SLEEP -->
<key value="0xe51af902" name="KEY_TV" /> <!-- KEY_TVRADIO -->
<!-- <key value="0xf00ff902" name="KEY_F7" /> KEY_RESOLUTION -->
<key value="0xf40bf902" name="KEY_F8" /> <!-- KEY_SUBT -->
<key value="0xf20df902" name="KEY_F9" /> <!-- KEY_TTXT -->
<key value="0xae51f902" name="KEY_F10" /> <!-- KEY_PIP -->
<key value="0xad52f902" name="KEY_F11" /> <!-- KEY_PIPSWAP -->
<key value="0xac53f902" name="KEY_F12" /> <!-- KEY_PIPLIST -->
<key value="0xa857f902" name="KEY_FN_F" /> <!-- factory key -->
<key value="0xf00ff902" name="KEY_FN_2" /> <!-- Resolution -->
<key value="0xbd42f902" name="KEY_FN_S" /> <!-- Check키. 마우스 토클로 -->
<!-- key value="0xfffff902" name="KEY_HOME" /> --> <!-- ??? -->
<key value="0xfffff902" name="KEY_SEARCH" /> <!-- ??? -->
<key value="0xfffff902" name="KEY_AUDIO" /> <!-- ??? -->
<!-- key value="0xfffff902" name="KEY_BACKSPACE" /> --> <!-- ??? -->
<key value="0xfffff902" name="KEY_FN_1" /> <!-- ??? -->
<!-- key value="0xfffff902" name="KEY_FN_2" /> --> <!-- ??? -->
<key value="0xfffff902" name="KEY_FN_D" /> <!-- ??? -->
<key value="0xfffff902" name="KEY_FN_E" /> <!-- ??? -->
<key value="0xfffff902" name="KEY_FN_F" /> <!-- ??? -->
<!-- key value="0xfffff902" name="KEY_FN_S" /> --> <!-- ??? -->
<key value="0xfffff902" name="KEY_FN_B" /> <!-- ??? -->
<key value="0x9f60f902" name="KEY_F15" /> <!-- 2016.06.02 10:10:50 jacob. 알렌과장 요청 -->
<key value="0x9e61f902" name="KEY_F16" />
<key value="0xf708f902" name="KEY_PROGRAM" /> <!-- ??? -->
<key value="0x9d62f902" name="KEY_F17" /> <!-- IP/SAT -->
<key value="0x9b64f902" name="KEY_F18" /> <!-- VOD -->
<key value="0x9a65f902" name="KEY_HOME" /> <!-- HOME -->
<key value="0x9966f902" name="KEY_F22" /> <!-- SHORTCUY -->
<key value="0x9867f902" name="KEY_F23" /> <!-- TV/RADIO/IP -->
<!-- um2070CH. 0x8f70f902:SAT2IP -->
<key value="0x8f70f902" name="KEY_FILE" /> <!-- SAT2IP -->
<!-- um2070CH. 0x8e71f902:PLUGIN -->
<key value="0x8e71f902" name="KEY_SENDFILE" /> <!-- PLUGIN -->
<key value="0x8d72f902" name="KEY_DELETEFILE" /> <!-- #19765 -->
<!-- #22338 mediastar -->
<key value="0x8a75f902" name="KEY_TAPE" /> <!-- F1, 0x180 -->
<key value="0x8976f902" name="KEY_SAT" /> <!-- SAT, 0x17d -->
<key value="0x8877f902" name="KEY_SAT2" /> <!-- Find, 0x17e -->
<key value="0x8778f902" name="KEY_VCR" /> <!-- Forever, 0x17b -->
<key value="0x8679f902" name="KEY_VCR2" /> <!-- APPS, 0x17c -->
<key value="0x857af902" name="KEY_CD" /> <!-- USB, 0x17f -->
<!-- UZ key + Fortis key -->
<key value="0x708ff902" name="KEY_TAB" /> <!-- tab -->
<key value="0x718ef902" name="KEY_BACKSPACE" /> <!-- backspace-->
<key value="0x728df902" name="KEY_F24" /> <!-- back -->
<!--key value="0x8a75ff00" name="KEY_F12" /> --> <!-- Group -->
<key value="0x738cf902" name="KEY_FN_F1" /> <!-- IPTV LIVE -->
<key value="0x748bf902" name="KEY_FN_F2" /> <!-- IPTV VOD -->
<key value="0x758af902" name="KEY_F19" /> <!-- VOD/LIVE -->
<key value="0x7689f902" name="KEY_ESC" /> <!-- key exit -->
<!-- Do not use 7788 for GTV Rcu -->
<!-- key value="0x7788f902" name="KEY_" /> --> <!-- Voice in gtv rcu -->
<!-- Do not use 7887 for GTV Rcu -->
<!-- key value="0x7887f902" name="KEY_" /> --> <!-- ... -->
<!-- Do not use 7986 for GTV Rcu -->
<!-- key value="0x7986f902" name="KEY_" /> --> <!-- .... -->
</fortis-key>
<fortis_UZ-key>
<key value="0x8f70ff00" name="KEY_F5" /> <!-- KEY_VFORMAT -->
<key value="0xcc33ff00" name="KEY_POWER" /> <!-- -->
<key value="0x8e71ff00" name="KEY_FN_2" /> <!-- Resolution -->
<key value="0xfe01ff00" name="KEY_1" /> <!-- -->
<key value="0xfd02ff00" name="KEY_2" /> <!-- -->
<key value="0xfc03ff00" name="KEY_3" /> <!-- -->
<key value="0xfb04ff00" name="KEY_4" /> <!-- -->
<key value="0xfa05ff00" name="KEY_5" /> <!-- -->
<key value="0xf906ff00" name="KEY_6" /> <!-- -->
<key value="0xf807ff00" name="KEY_7" /> <!-- -->
<key value="0xf708ff00" name="KEY_8" /> <!-- -->
<key value="0xf609ff00" name="KEY_9" /> <!-- -->
<key value="0xff00ff00" name="KEY_0" /> <!-- -->
<key value="0x9f60ff00" name="KEY_TAB" /> <!--key tab. newkey-->
<key value="0xe817ff00" name="KEY_BACKSPACE" /> <!--key backspace. newkey-->
<key value="0xae51ff00" name="KEY_INFO" /> <!-- -->
<key value="0xe51aff00" name="KEY_MENU" /> <!-- -->
<key value="0xa857ff00" name="KEY_F24" /> <!-- KEY_RECALL, keylayout에서 back으로 변경. -->
<key value="0xe11eff00" name="KEY_ESC" /> <!--key exit-->
<key value="0xf40bff00" name="KEY_UP" /> <!--key up-->
<key value="0xf10eff00" name="KEY_DOWN" /> <!--key down-->
<key value="0xee11ff00" name="KEY_RIGHT" /> <!--key right-->
<key value="0xef10ff00" name="KEY_LEFT" /> <!--key left -->
<key value="0xf20dff00" name="KEY_ENTER" /> <!--key ok -->
<key value="0xcd32ff00" name="KEY_FAVORITES" /> <!-- -->
<key value="0xe41bff00" name="KEY_PROGRAM" /> <!-- EPG -->
<key value="0x8a75ff00" name="KEY_F12" /> <!-- Group. newkey. -->
<key value="0x936cff00" name="KEY_VOLUMEUP" /> <!-- -->
<key value="0x926dff00" name="KEY_VOLUMEDOWN" /> <!-- -->
<key value="0xab54ff00" name="KEY_HOME" /> <!-- HOME. newkey. -->
<key value="0x956aff00" name="KEY_CHANNELUP" /> <!-- -->
<key value="0x946bff00" name="KEY_CHANNELDOWN" /> <!-- -->
<key value="0xad52ff00" name="KEY_F1" /> <!-- red -->
<key value="0x9c63ff00" name="KEY_F2" /> <!-- green -->
<key value="0x9d62ff00" name="KEY_F3" /> <!-- yellow -->
<key value="0x9e61ff00" name="KEY_F4" /> <!-- blue -->
<key value="0xcb34ff00" name="KEY_FN_F1" /> <!-- f1 -->
<key value="0xca35ff00" name="KEY_FN_F2" /> <!-- f2 -->
<key value="0xc936ff00" name="KEY_FN_F3" /> <!-- f3 -->
<key value="0x916eff00" name="KEY_FN_F4" /> <!-- f4 -->
<key value="0xf50aff00" name="KEY_MUTE" /> <!-- -->
<key value="0xd728ff00" name="KEY_PVR" /> <!-- key playlist-->
<key value="0x8976ff00" name="KEY_F6" /> <!-- KEY_SLEEP -->
<key value="0x8b74ff00" name="KEY_FN_S" /> <!-- mouse cursor -->
<key value="0xde21ff00" name="KEY_REWIND" /> <!-- << -->
<key value="0xdd22ff00" name="KEY_PLAY" /> <!-- > -->
<key value="0xdc23ff00" name="KEY_PLAYPAUSE" /> <!-- || -->
<key value="0xdb24ff00" name="KEY_FORWARD" /> <!-- >> -->
<key value="0x8d72ff00" name="KEY_PREVIOUSSONG" /> <!-- |< -->
<key value="0xd926ff00" name="KEY_STOP" /> <!-- D -->
<key value="0xd827ff00" name="KEY_RECORD" /> <!-- -->
<key value="0x8c73ff00" name="KEY_NEXTSONG" /> <!-- >| -->
<key value="0x31ceff00" name="KEY_F19" /> <!-- VOD/LIVE ( New one. ) -->
</fortis_UZ-key>
<dreamlink-key>
<key value="0xff00fe01" name="KEY_POWER" /> <!-- -->
<key value="0xa758fe01" name="KEY_FN_2" /> <!-- Resolution -->
<key value="0xea15fe01" name="KEY_UP" /> <!--key up-->
<key value="0xe916fe01" name="KEY_DOWN" /> <!--key down-->
<key value="0xe817fe01" name="KEY_RIGHT" /> <!--key right-->
<key value="0xeb14fe01" name="KEY_LEFT" /> <!--key left -->
<key value="0xed12fe01" name="KEY_ENTER" /> <!--key ok -->
<key value="0xee11fe01" name="KEY_ESC" /> <!--key exit KEY_BACK-->
<key value="0xef10fe01" name="KEY_MENU" /> <!-- -->
<key value="0xbc43fe01" name="KEY_F24" /> <!-- KEY_RECALL, keylayout에서 back으로 변경 -->
<key value="0xe619fe01" name="KEY_INFO" /> <!-- -->
<key value="0xaf50fe01" name="KEY_VOLUMEUP" /> <!-- -->
<key value="0xae51fe01" name="KEY_VOLUMEDOWN" /> <!-- -->
<key value="0xf00ffe01" name="KEY_CHANNELUP" /> <!-- -->
<key value="0xad52fe01" name="KEY_CHANNELDOWN" /> <!-- -->
<key value="0xa55afe01" name="KEY_FN_S" /> <!-- Check키. 마우스 토클로 -->
<key value="0xec13fe01" name="KEY_HOME" /> <!-- HOME. newkey. -->
<key value="0xfc03fe01" name="KEY_MUTE" /> <!-- -->
<key value="0xa45bfe01" name="KEY_F9" /> <!-- Apps. new key. -->
<key value="0xfe01fe01" name="KEY_1" /> <!-- -->
<key value="0xfd02fe01" name="KEY_2" /> <!-- -->
<key value="0xf906fe01" name="KEY_3" /> <!-- -->
<key value="0xfb04fe01" name="KEY_4" /> <!-- -->
<key value="0xfa05fe01" name="KEY_5" /> <!-- -->
<key value="0xf807fe01" name="KEY_6" /> <!-- -->
<key value="0xf708fe01" name="KEY_7" /> <!-- -->
<key value="0xf50afe01" name="KEY_8" /> <!-- -->
<key value="0xf40bfe01" name="KEY_9" /> <!-- -->
<key value="0xf10efe01" name="KEY_0" /> <!-- -->
<key value="0xb847fe01" name="KEY_F1" /> <!-- red -->
<key value="0xbe41fe01" name="KEY_F2" /> <!-- green -->
<key value="0xbd42fe01" name="KEY_F3" /> <!-- yellow -->
<key value="0xe21dfe01" name="KEY_F4" /> <!-- blue -->
<key value="0xb34cfe01" name="KEY_REWIND" /> <!-- << -->
<key value="0xb44bfe01" name="KEY_PLAY" /> <!-- > -->
<key value="0xb54afe01" name="KEY_PLAYPAUSE" /> <!-- || -->
<key value="0xb24dfe01" name="KEY_FORWARD" /> <!-- >> -->
<key value="0xb14efe01" name="KEY_PREVIOUSSONG" /> <!-- |< -->
<key value="0xb649fe01" name="KEY_STOP" /> <!-- D -->
<key value="0xb748fe01" name="KEY_RECORD" /> <!-- -->
<key value="0xb04ffe01" name="KEY_NEXTSONG" /> <!-- >| -->
<key value="0xe718fe01" name="KEY_PROGRAM" /> <!-- EPG -->
<key value="0xac53fe01" name="KEY_F10" /> <!-- LIVE. newkey. -->
<key value="0xab54fe01" name="KEY_F11" /> <!-- VOD. newkey. -->
<key value="0xbb44fe01" name="KEY_F12" /> <!-- Group. newkey. -->
</dreamlink-key>
</key_xml>
