17MB211S LOGO JVC
bubul
15 Eyl 2018
I need help after you replaced the main board from Hitachi on JVC tv, the Hitachi logo appears, now I need the JVC logo file, can you send me the procedure is like that but I only need the JVC logo file.
thank you
Boot Logo Update
1. Create "spi" folder into the USB root.
2. Copy your jpeg format file into the "spi" folder which is located on USB, and rename this file as "boot_logo.bin". (Jpeg is natively supported as boot logo. So, you do not need to convert jpeg with any external tool.)
3. Plug the USB to TV's USB-1 port.
4. Make "USB operations" from the service menu.
5. New files will be updated after power off/on.
B bubul
Logo link
Boot logo update
Extract the spi folder from the zip
Copy into an empty USB flash drive
Insert the USB stick into the USB port of the TV
Press MENU 4 7 2 5 on the remote control
Go to the "USB operations" line in the service menu and press OK.
The new logo will be uploaded after power on / off.
bubul
15 Eyl 2018
O Çevrimdışı
Omeeerr
1 Nis 2020
32
B bubul
Logo link
Boot logo update
merhaba hocam linkin süresi dolmuş yeniden paylaşabilirmisiniz?
