17MB110P (Toshiba 55) problem
max666
8 Ara 2019
Please help with Toshiba 55L3763DG
MB, 17MB110P 23411728 55"
The TV turns on, shows the boot logo (Toshiba) and then turns off.
I changed the MB, even flashed the Vestel MB110 to recover - the problem is the same, but with the VESTEL logo.
I also changed the power supply, it doesn't help.
The TV turns on, shows boot logo (Toshiba) and then powers off.
I have changed MB, even flashed to recovery Vestel MB110 - it is the same, but with VESTEL logo.
I have also change power supply.
yokoono Çevrimdışı
73
I do not know. A cheap CH341A programmer.
max666
8 Ara 2019
Teşekkürler! Bunu deneyeceğim!
EPROM'un LCD panelde olduğunu varsayıyorum?
Thank You! I will try this!
I presume the EPROM is in the LCD panel?
max666
8 Ara 2019
i have programmed flash on both motherboards (some problems with lock, had to use neo programmer and now both verify Ok with new bin). Unfortunately nothing has changed. TV shows logo then shuts off.
Original MB was working 3years and this happened. Then I bought 2nd used MB from same TV model and after 1year same thing. Maybe they overheat?
Can I use 17MB110P from other LCD size and then program this flash?
thanks for all the help!
