İyi günler.
Panel: Vestel PDU43UF82/4
Ücret: 17MB135VS
Seri numarası: 8907771 200001
Ana ücret değiştirilmedi.
HDMI modunda 2 yıl sessizce çalıştım. Üzerine bir görüntü geldi, panelin kendisi açıldı. Sinyal olmadığında panel kapatıldı. Ama bir gün açılmayı ve tepki vermeyi bıraktım. Uzaktan kumandayı açmaya çalıştık, hayır da. Rölenin tıkladığını fark ettiler, ancak görüntü yok. RS-232 ile bağlandım, logonun altında:
AC_ON
BIST0-OK
BIST1-OK
_U
Relocation Offset is: 13E00000
[AT][MB][start ub][648]
U-Boot 2011.06-dirty (May 25 2021 - 17:06:26) MBOT-1106.0.10.0b7f15b1d63177ac33a6cэVBE_CODE = 393
VBE_CODE_FT = 402
[VID]CPU Temperature: 38
[VID]SSID: 109
[VID]OSC: 85
[VID]CPU case: 2
[VID]CORE case: 2
[VID]CPU power tune to 0.95V
яmsIR_Initializetune to 1.0V
[SYS][Utopia]: Function = SYSOpen, Line = 1039, current resource pri_shm content is: 0
[SYS][Utopia]: Function = SYSOpen, Line = 1058, [SYS INFO] OPEN INSTANCE...
create instance at 3D86D5E8 with private size 124 bytes at 3D86D630
[MIU][Utopia]:
[MIU INFO] miu opencreate instance at 3D86D6B0 with private size 80 bytes at 3D86D6F8
Flash is detected (0x0507, 0xC2, 0x20, 0x15)
create instance at 3D86D750 with private size 48 bytes at 3D86D798
uboot held at [3D4DDF60~40000000],size=02B220A0
CPU : Macan
Board: BD_MST253A_D01A_S_MACAN
DRAM: 512 MiB
Now running in RAM - U-Boot at: 3F500000
NAND: [NC_Init] SDR NAND is detected
CIS is found @Blk0
FCIE is set to 62MHz
512 MiB
*** Warning - set default for mtdparts, using default environment
Creating 1 MTD partitions on "nand0":
0x000000980000-0x000000D80000 : "mtd=2"
Bad block table found at page 131008, version 0x04
Bad block table found at page 130944, version 0x04
nand_read_bbt: Bad block at 0x000002480000
nand_read_bbt: Bad block at 0x000002BC0000
nand_read_bbt: Bad block at 0x000003200000
UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size: 262144 bytes (256 KiB)
UBI: logical eraseblock size: 253952 bytes
UBI: smallest flash I/O unit: 4096
UBI: VID header offset: 4096 (aligned 4096)
UBI: data offset: 8192
UBI: attached mtd1 to ubi0
UBI: MTD device name: "mtd=2"
UBI: MTD device size: 4 MiB
UBI: number of good PEBs: 16
UBI: number of bad PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 250
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 1
UBI: total number of reserved PEBs: 15
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 42/24
Volume "MPOOL" found at volume id 0
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Set MAC default
MAC: 0x0: 0x30: 0x1B: 0xBA:0x2: 0xDB
Requested Led2 State 0x1E012C: 0x1
RC type offset = 0x1E0080, type = 0x0
uart spi offset = 0x1E0126, value = 0x0
UART Disabled
Görüntü yok ve komut satırına hiçbir şey girmiyor. Perpoşlaştırmaya çalışmak istiyoruz.
Geri bildiriminiz için şimdiden teşekkür ederim!
