thanks for your help
No picture appears.
Install the software on the MB96 link, the motherboard of the television, to which you added the barcode image, and write the result. software link
The responsibility is entirely yours. Extract the software from the zip. Copy it into an empty flash memory formatted in Fat32 Format. Plug the flash memory into the usb port of the tv. Press and hold the OK button on the remote control. Plug the TV into the socket. Release the OK button when the front LED starts to flash rapidly. The software will be installed in 2-3 minutes.
The motherboard of the television that belongs to the barcode you have added the picture of is MB96.
You Typed MB95 If MB96 is the same, install the software in my previous message. Write the result
Google translate
Hello. I'm looking for firmware for
hitachi 55hl9000g. I have a problem with movie sense function and dolby vision content.
17MB95 or 17MB96 ?. Cod panel (VES400xxxxx) ??.
It's hardware and software profile name start by mb95
OK. The motherboard is 17MB95. For the panel code (VES400 ??????) you need to lower the TV cover. It is written on a small white label glued to the panel.
google translate
Iinstalled mb95 software according to instruction now the tv dont show even the vestel logo. it seems dead.
Anakart üzerindeki ve panel üzerindeki barkod resmini buraya ekleyin bu şekilde yazılım verilemez. Bu bilgileri @yokoono usta da sizden istiyor. Televizyonun arka kapağını açın resimleri çekip buraya ekleyin.
ARROW. The motherboard is 17MB95. For the panel code (VES400 ??????) you need to lower the TV cover. It is written on a small white label glued to the panel.
there is not any other label!!!
