These files can only be installed from service mode and I can't see the image. Other versions of 17MB110P don't fix the image either. Is it the software's fault, or maybe the hardware. Please check print:
Kod:
UART_115200
DC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
_U
Relocation Offset is: 0CC00000
[AT][MB][start ub][267]
U-Boot 2011.06 (May 19 2016 - 17:22:40)  MBOT-1106.0.10.1364428
[CODE]UART_115200
DC_ON
MIU1_DQS-OK
BIST0-OK
BIST1-OK
_U
msIR_Initialize
Function = UtopiaOpen, Line = 234, UtopiaOpen[MODULE_MIU] strange failed
having MODULE_BDMA
having MODULE_UTOPIA
Open MIU failFlash is detected (0x0507, 0xC2, 0x20, 0x15)
uboot held at [2E2DDF60~2FA00000],size=017220A0
CPU  : Munich
Board: BD_MST220E_D01A_S
DRAM:  250 MiB
Now running in RAM - U-Boot at: 2ED00000
NAND:  [NC_Init]        SDR NAND is detected
CIS is found @Blk0
FCIE is set to 62MHz
512 MiB
*** Warning - set default for mtdparts, using default environment
Creating 1 MTD partitions on "nand0":
0x000000880000-0x000000C80000 : "mtd=2"
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
Can't find "CTRL" partition
restore UBI scan
Volume "MPOOL" found at volume id 0
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MAC:  0x48: 0x6D: 0xBB: 0xA:0x7E: 0xC7
RC type offset = 0x1E1AA0, type = 0x0
uart spi offset = 0x1E1B46, value = 0x0
UART Disabled
ower Down
You asked for the panel profile and I posted it. I don't have software.
Panel files will definitely be useful - thank you. But for now I'm looking for 17MB110P software.
Are you sure this is a software bug?
Missing image and sound. Backlight present.
It can also be a hardware problem. For example, cold solder joints on the processor, defective processor, improperly powered processor. When you ask for software, I assume that you have done all the measurements and the cause of the defect is clear.
Merhaba, regal marka televizyonumuz var. Forumda araştırdığım kadarıyla yazılım çökmesi olarak gözüküyor fakat biz her hangi bir yükleme falan yapmadık kendiliğinden oldu. Bu televizyonun bilgilerini paylaşsam bana kurtarmam için gerekli dosyayı sağlar mısınız? Çünkü araştırdım fakat nasıl uygun yazılımı bulacağımı anlayamadım. Teşekkürler.
Bilgiler burada.
Sorun televizyon açıldığında regal yazısı geliyor ve standby ışığı yanıp sönüyor.
Gerekli yazılımı paylaşırsanız minnettar olurum.
Bilgiler burada.
Yazılım Verildi
Sorumluluk tamamen sizdedir.
Yazılımı zipten çıkartın.
Flash belleği tv nin usb giriş portuna takın.
Kumanda üzerinden OK tuşuna basılı tutun.
Tv nin fişini prize takın.
Yazılım 1-2 Dakika içerisinde yüklenecektir.
9X Anakartlarda ledin hızlı hızlı yanmaya başlaması 30 Saniye sürebilir yanıp sönme başlamadan OK tuşunu bırakmayın.
Sizin tv MB9X Anakartlıdır.
Uzaktan kumanda arızalı olabilir.
:) 3 kumandası var yazılımla oynadıktan sonra oldu giray ile sıkıntı olmuyordu toolbox ile yapınca bu şekilde oldu full yazılım atarsanız size zahmet
Merhaba,
tv çöp gibi yatıyor, yardımcı olan varsa şu tv yi ayaklandıralım,
Full yazılımı varsa atabilirmisiniz?
en güncel ve stabil yazılımı rica edebilir miyim
Tv deki sorun nedir?
Yazılım kitleniyor tv tuşları ve kumanda çalışmıyor kumandadaki mute tuşuna basıncada cihaz kitleniyor yayın var ancak kumanda ve üzerindeki tuşlar işlemiyor fişi çekip takımca düzeliyor
