cadkey
16 Kas 2017
30
In France
24,244
cadkey' Alıntı:
I read that with version 2.43.2.0 the tv was hdr, but I have no HDR.
hdr active information came from some members but there is no technical explanation that this is 100% correct. We can check your serial number for HDR support. :ok:
cadkey
16 Kas 2017
30
Thank you for your help and your patience. It was not easy for me to understand the Turkish language which is very badly translated with google
What is the television production code?
What is it for?
24,244
cadkey' Alıntı:
What is it for?
I use google translate because I do not speak english. production code is the code that determines the properties of the television. This code decides which properties will be available in production.
cadkey
16 Kas 2017
30
Ok, and latest question please
In my menu, I can't modify led backlight intensity,
the menu is grayed out, not accessible. is this normal?
24,244
cadkey' Alıntı:
if you set the economy mode to automatic, the gray area (the passive area) is active and you can adjust the dimming.
cadkey
16 Kas 2017
30
Ok, I did not think about that, it makes sense.
Thank you very much for your help, I know better now my tv and its possibilities.
Thanks again
