thunder1111 Çevrimdışı
thunder1111
26 Kas 2019
12
56
Try
Thank you, but does not work, I would need the original firmware, probably an older, Telefunken gives me only the newest, no older, and Karcher-service supposedly does not know the serial number, so no help, thank you for the attempt to help, but it has no sense fishing in the murky, I give up and dispose of an intact TV :(
thunder1111
26 Kas 2019
12
56
Copying the profile to the TV is done other than the software update. With USB Option input. Do you know the procedure?
Not really, I tried to get with the DownloadProfile.mb110 the mb110_swprofile.bin on the tv, but there is the wrong firmware installed and don`t recognize the profile, I don' t see a chance, when you know a way step by step I would try, otherwise I give up and try to sell this TV.
yokoono Çevrimiçi
Try it like this:
1. Put a blank folder called downloadprofile.mb110 on the stick
2. Copy the folder called PROFILE on the stick (you can find it in the profile I gave you). You will have 2 folders: downloadprofile.mb110 (empty) and PROFILE (with my profile).
3. Turn on the TV and insert the stick into the USB. If you are asked to dry the stick, choose NO.
4. Type MENU and 4725
5. Scroll down to USB Operations and type OK.
6. Wait 20-30 seconds and exit MS (back key)
7. Turn off the TV from the remote control. The stb LED will blink fast. When it stops blinking it is ready.
8. Remove the stick and turn on the TV.
thunder1111
26 Kas 2019
12
56
Try it like this:
Does not work, do you have an older firmware of the firmware you sent me? When not, I don' t want to steal more time of you, then it doesn' t work and good is.
23,230
65
1- zip ten çıkart
2- Usb diski FAT32 formatla , Profile klasörünü usb kök dizine kopyala (USB 3.0 olmasın)
3- USB yi TVye tak , menu +4+7+2+5 ile USBOperations gel ve OK tuşla
4-Tvyi kapat-aç
1- Extract from zip
2- Copy usb disk to FAT32 format, profile folder to usb root directory (not USB 3.0)
3- Plug USB into TV, menu + 4 + 7 + 2 + 5 with USBOperations and press OK
4-Turn off-on the TV
thunder1111
26 Kas 2019
12
56
I have no access to the menu, because the screen freezes after I install the right firmware, I can't do anything, the TV don' t react to commands. And the profile I can' t install to the wrong firmware, because the TV don' t recognize the profile from another panel, and about my panel I find nothing in www. The panel is 43_vesund12_2D.
23,230
65
Bu tv senin değilmi?
İlk önce kurulumu yap,
Yayın seçimi yapma, yalnızca kurulum yapılsın,
Kurulum bitince profilleri menü +4+7+2+5 ile TV ye yükle.
yokoono Çevrimiçi
Because the problem was not solved you can rewrite the flash memory. But you need a programmer.
kozzade
12 Ara 2019
Titanium menü görünümü
vestel Titanium menü
