U Çevrimdışı
Uluyanhamsi
4 Ara 2017
8
Selamun aleykum, tv ye 4 ay önce güncelleme yapmak istedim olmadi. Tv ışığı yanıp sönmeye başladı. Sağolsun ado kurtarma yazılımı yollamıştı duzelttim. Şimdi birçok uygulama yok malesef. Tkgs çift ekran ve smart bölümü birçok uygulama. Tekrar nasıl yapabilirim. Eski halini ozluyorum
Unutmadan, şuan versiyon V.2.2 4t
Tv çökmeden önceki sürüm 3.6.6n idi. Şimdiden teşekkür ederim
Mb90 yazıyor.
r2005rom
11 Kas 2018
[QUOTE = "Ado, post: 7751, member: 363"] Dear Friends;
First of all, even though we know that there is no longer any need to talk about the risks of software installation, I would like to start by reminding you that the software installation is a complete adventure with the idea of aba I wonder what will happen? Düşün.
Especially for MB9X series users, and especially for FAZ2 users, this topic is a complete adventure, so please do not install software on the grounds of "ACABA" if you do not have a problem. I would like to remind you about this situation in advance, such as system crash, service, motherboard replacement, high service cost.
This topic only shares the original core software.
Please read the important warning section at the end of the article.
I do not provide information about what has changed in the upgraded software, and these are expressed in the forum by our friends as user experience.
Please note that the issuer of the software itself may cause problems with the product under the warranty conditions.
When installing the core software X for some reason you will need full software to install the TV.
Full software is large in terms of size and because it is special for every TV, we do not want to send a full software to every friend who asked for it in time.
Authorized services already provide free service to all products that fail, but please note that they have the hardware to detect the replacement software.
All of these warnings are to protect both your security and your rights, but also to prevent unnecessary failure of your product.
MB82 recovery software can be used for Vestel TV Malfunctions. Kernel softwares are not a factor in MOSCOPE TV situations, but are a factor in software-based bug situations and product performance improvements.
After all this information, how to install the software.
Before and after the software installation, please do not forget to perform a version check by entering the service menu with MENU 4725.
All softwares in this area can be downloaded from USB. In this sense, it is important to have a high data rate of the USB, because in some cases, ira Image shows the video but I cannot install the software in. I would like to inform you that Sandisk hasn't had much negative return in memory.
There are 2 methods to install software (other than the pro methods installed with Debug cards)
A- FULL software installation method
The order in this Method is as follows
1- Software that is suitable for free memory formatted as FAT 32 is placed as CLASSless
2- TV plug is pulled
3- Memory is attached to the TV
4- Press and hold the OK button of the remote control and insert the TV plug
5- When the STBY light starts to flash fast, press the OK button.
TV will be turned on in two minutes.
B- CORE software installation method:
1- Appropriate software is inserted into free memory formatted as FAT32
2- Connect to USB TV
3- MENU 1505 is encoded and the answer ır YES ır is answered YES
In two minutes the TV will open itself by completing operations.
FULL software is loaded only with the FULL method but the ROW softwares do not have any downloadable damage by either method [sm = ok.gif]
The following software is the most current official software possible. For more detailed installation instructions, please visit for information and control of VESTEL [sm = ok.gif]
17MB82 1.35
[Hidden content]
17MB82 1.37
[Hidden content]
17MB82 RECOVERY
[Hidden content]
17mb90_mb91r1r2_mb92r3_mb95_mb95s_mb95m_faz3_v366y
[Hidden content]
17MB91 3.3.8.c Stable version
[Hidden content]
[Hidden content]
17mb91r3_mb92r4_mb96_faz3_v376n
[Hidden content]
17mb96_3.7.6.s
[Hidden content]
17MB97_98_0.45.23.32
[Hidden content]
17MB97-98 0.45.23.39
[Hidden content]
17MB100-34.23
[Hidden content]
17MB100_34.25
[Hidden content]
17MB100 2.7.0.0.
[Hidden content]
17MB110 2.22.0.0
[Hidden content]
17MB110 2.32.0.0
[Hidden content]
17MB110_2.24.1.0_FBTV
[Hidden content]
17MB110 2.35.15.0
[Hidden content]
17MB110 2.35.40
[Hidden content]
17MB110S 3.16.6.0
[Hidden content]
17MB110S 3.16.12.0
[Hidden content]
17MB110S 3.26.6.0
[Hidden content]
17MB120-2.29.6.0
[Hidden content]
17MB120-2.29.11
[Hidden content]
17MB120-2.36.0
[Hidden content]
17MB120-2.40.2.0
[Hidden content]
17MB120-2.40.6.0
[Hidden content]
17MB120-2.43.2.0
[Hidden content]
17MB120 2.45.70
[Hidden content]
17MB120 2.45.101
[Hidden content]
17MB120 2.45.12.1 NETFLIX
[Hidden content]
17.12.2016 (23.05.2018)
[Hidden content]
17MB130 3.19.2.0 (NONCONNECTED)
[Hidden content]
17MB130 3.19.8.0 (NONCONNECTED)
[Hidden content]
17MB130 3.19.11.0 NONCONNECTED
[Hidden content]
MB130-3.3.7.3.0 (CONNECTED)
[Hidden content]
17MB130 3.4.4.6.0 (CONNECTED)
[Hidden content]
17MB130 3.4.7.1.1.0 (CONNECTED)
[Hidden content]
17MB130 CONNECTED 3.62.4.0 Yotube, Netflix Çözüm içerir
[Gizli içerik]
17MB130 3.62.7.0
[Hidden content]
17MB130 3.62.13.0
[Hidden content]
17MB130 3.62.24
[Hidden content]
17MB130 3.62.29 CARBON
[Hidden content]
17MB130 3.62.29 TITANIUM
[Hidden content]
17MB130 3.62.30 CARBON
[Hidden content]
17MB130 3.62.30 TITANIUM
[Hidden content]
17MB140 CARBON menu
[Hidden content]
17MB140 TITANIUM Menu
[Hidden content]
17MB140 1.38.100
[Hidden content]
17MB211 0.49.10
17MB211 0.56.1.0
[Hidden content]
17MB211 0.59.2.0
[Hidden content]
IMPORTANT WARNING;
The TV software X may crash for some reason, the responsibility of the crashed system belongs to the installer. In the Forum, this information is completely shared with the purpose of SUPPORT and HELP, so I would like to remind you that you should not hold us responsible for any problems.
There is a high quality sharing of information in the forum about possible problems, so it is recommended that you take some advantage of this information instead of attempting to install software with 2 lines of writing.
You can also use the operating system for your installation.
Full software and core software.
Please note that the invisible article cannot be used in the article. I'm going to be able to find out what the problem will be. of [/ QUOTE]
[QUOTE = "Ado, post: 7751, member: 363"] [/ QUOTE]
like!
commigere
17 May 2018
88
kardeş ilk sayfada bulunan google drive linkleri sağlam değil. yarıda kesiliyor indirme başarısız diyor antivürüs programı kapatılarak denendi sonuç aynı bilgin olsun
ssip tv ile alakalı sıkıntılar var vod lar görüntüleniyor maç yayınları görüntülenmiyor ses var siyah ekran görüntü yok 49inch 9650 cihaz mb 120 anakart
"http://xxxx.xxxx.xxxx:xxxx/live/kullanıcıadı/sifreniz/12345.ts"
Link bu şekilde olmalı. Ben de dün akşam düzelttim tek tek uğraşarak. IPtv sağlayıcısını bilgilendirdim ama pek umursamadı beni.
Vlc'de açılıyor fakat Ott Player ve SS-IPTV'de ses gelip görüntü gelmiyorsa sebep indirilen m3u listesinin içindeki canlı yayınların linklerinin yukarıdaki gibi olmamasındandır.
Not defteri programı ile açıp tek tek düzeltmeniz gerekmekte maalesef. Ctrl+H kombinasyonuyla live kısmını ekleyebilirsiniz ama .ts kısmı için bir kolaylık bulamadım şimdilik.
ergun
13 Kas 2018
Adem Helvacı Ado,
tv markası regal seri nosu 7098184 300406
model ld42f5141s
kart modeli 17mb82s
full yazılım rica ediyorum seri numarasını duzettlm eğer ilgilenitseniz sevinirim DOSYA SILINMIS BANADA YOLLAYABILIRMISIN cucuergun@hotmail.com TNK
freeheart44
30 Ağu 2018
8
Merhaba tvde bir kaç yazılım denedim
Normal çalışıyordu. Bugün geldim açılmıyor vestel yazısı geliyor sonra sürekli mavi ışık. Ne yapmam lazım 43 inç mb120 anakartlı model
Tv seri no
7561269600115
43ua8900
cagatayucuzal@hotmail.com
Fariz3939
14 Kas 2018
@ sota
hem döktürmüş.
hemde
Doktormuş bu konuda
üstün tvci @Ado bir tv doktorudur. :bye:
ama ado kardeşim ben hala tüplü tvleri seviyorum ya ısınamadım gitti şu ince tv lere.
yok o sıcaklık be tüplü tvleri seyrdettiğimiz yıllardaki sıcaklıktan bahsediyorum sen anlamışsındır :ok:
inan bu durum kişi bazında benim ruhumada yansıyor sevemedim gitti şu panel dediğiniz tvleri.
en son bir tane tüplü panel tv aldıydım. yani resmen tüpe panel uygulanmış deniyordu ne ölçü dorudur bilemem. nasıl desem DRCMF vs philips pixel plus gibi zaten tv üstündede hd ready yazıyor. sony 86 ekran o bile çok zevk vermedi ama şuanki tv lere değişmem ek hoperlörle vs işi olmuyor tam bas tam stereo vs güm güm ötüyor.
millet bunu nereden buldun diyor bende dhde bir arkadaş vardı pek girmem tv konularına bir tv lazıom olunca lcd leri beğenemedim okurken yazısını gördüm dua ediyorum arkadaş ismini unuttu. şimdi millet nereden buldun bunu diyor diyorum japonyadan geldi =)
Kolay gelsin abi mb100-64 benimki hangisi oluyor vestelin
