cneg21
5 Ara 2023
Merhabalar Sunny 43DAL13 , sunny bu teknoloji senin için yazısında kalıyor. 13at213V1.0 için kurtarma yazılımı gerekiyor.
arpegio
12 Kas 2025
6
54
Vestel motherboard
Hello everybody
I'm looking for a Vestel motherboard with Android that has the same connectors as the 17MB120. Electrically compatible. Does anyone know if this motherboard exists? Thanks
yokoono Çevrimiçi
Vestel motherboard
Hello everybody
There may be motherboard/panel compatibility issues. Power connector problems. It is possible that there are mechanical issues.
Also tell me what code the TV panel has.
H Çevrimdışı
Hiro5005
19 Eki 2024
Merhaba iyi çalışmalar
Seg marka TV için yazılıma ihtiyacım var TV acılıyor logo geliyor sonra açılmıyor
Kolay gelsin
arpegio
12 Kas 2025
6
54
The panel is VES550QNDS-2D-U11 but I don't think the panel will be a problem because I have the VESTEL_D1_Plus_PNL and VESTEL_D1_Plus_TMG files for my panel. I want to replace the 17MB120 main board with another one running Android that has the same connectors. Does this motherboard exists?
yokoono Çevrimiçi
In case of problems. I have nothing in the archive for this panel. You can't do anything with the panel profiles if you change the motherboard model. If you have time to study, look for 17MB170, 17MB171, 17MB185.
