melikgazi
14 Tem 2019
11
31
Merhaba ben daha önce yazılım güncelleme ile yazmıştım sağolsun teraspy yardımcı olmuştu.Şimdi bu güncellediğim güzel çalışan Tv'me ıp tv programı yükleyeceğim smart kısmına ama vestelin desteklediği ıp tv ssıptv uygulaması ben başka bir ıptv uygulaması yüklemek istiyorum acaba ihtimali var mı ?
ottplayer mevcutsa kullanabilirsin
thunder1111 Çevrimdışı
thunder1111
26 Kas 2019
12
57
I'm looking for the Telefunken original firmware for the models
SN: 7702579 600279
and
SN: 7702573 600155
The first is a: D43F287N4CW
Second is a: D40F280N4CW
I think I need this package:
• mb110_en.bin
• mb110_RomBoot.bin
• mb110_PM51.bin
•usb_auto_update_G6.txt
My problem is, always I restart the TV I have to do a new installation, every time.
Please in english or german
yokoono Çevrimdışı
SN: 7702579 600279
and
SN: 7702573 600155
• mb110_en.bin
• mb110_RomBoot.bin
• mb110_PM51.bin
To help you have to post the code of the motherboard and the panel.
Did you also reset to factory settings?
Have you rewritten other software than the original one?
barby16_06
28 Eyl 2019
hi to all.
i have a problem with my wellington tv
Model: WL24HD279SW
SN: 8122254 800200
MB: 17MB110S
PSU: 17IPS61-5
PANEL: V236BJ1-P01 REV CB
I tried all the core updates from the first page but no luck.
when i plug usb in tv end press ok and plug tv led start bllink fast for 3 seconds and then nothing happens.
I need full software to rewrite on tv.
i saw that it was a version MB110S 3.16.12.0 Core Software on firs page but have no link for download
Also mention that i have also rt809h and tryed different dumps on 2mb memory. but again no luck. now is stock dump on 2 mb.
please any full software or any advices.
yokoono Çevrimdışı
There are 2 types of software on the forum: FULL and CORE. The FULL software is for the stick and is installed using the OK key. The CORE software is for stick and is installed by entering MENU + 1505. If in the current situation the TV is working enter MENU + 4725 and take a picture.
barby16_06
28 Eyl 2019
forgot to mention. my tv is not turning on.
no image. led blinks for 7 times and then remain red.
For this i tryed all the software by pressing OK on the remote and no luck at all.
tryed with different usb flash drive, led blinks 3 times fast and then remain on. no image, no backlight, no response from remote after that
yokoono Çevrimdışı
The software on the first page is CORE. It does not install with the OK key. It is installed from MENU + 1505. But if the TV works.
Because the TV does not turn on (it does not boot) you will need the FULL software. I do not have FULL software for 17MB110S. I have no flash software for SPI memory. I'm sorry I can't help you.
L.E.
If you rewrote the FLASH memory (MX25L1605) with the original software and the TV does not work it means that the content of the NAND memory is altered and you have to look for software for it. Can be rewritten with RT809H.
Or RT809H did not copy the contents of the memory correctly.
