Bunu yarın inceliyip bilgi vereceğim.
hosbulduk Çevrimdışı
hosbulduk
9 Kas 2018
3,721
Hello, i need help. I uploaded firmware with wrongmb140_mboot.bin file from the other post here on my JVC LT-32VF30K and now the TV is bricked! The firmware was V138230 27884398 https://tavsiyeforumu.com/konu/mb14...kti-ve-ilk-defa-tavsiyeforumunda.5588/page-11
Need HELP! Thank you!
You should actually install the following software on page 1. "Titanium Kurtarma Yazılımı (Vestel Hariç Diğer Markalar):. If you haven't installed, try installing this software. https://tavsiyeforumu.com/konu/mb140-kurtarma-yazilimi-cikti-ve-ilk-defa-tavsiyeforumunda.5588/
blackwind
6 Nis 2018
18
Yes but the picture when the tv is on is bricked. I think that this firmware was with wrong mb140_mboot.bin . So now i need an original firmware with correct mboot.bin :(
hosbulduk
9 Kas 2018
3,721
The software you installed is essentially a rescue software for non-Vestel TVs with an mb140 mainboard. If this fails, you will not be able to find any software here because your TV is an export product.
yokoono Çevrimiçi
I found out that the TV is 17MB140. For a correct software you must also say the panel code. To do this you need to undo the TV cover and find the code (VES315 ??????) on a label.
You can also try the repair kit for 17MB140.
kolay gelsin tv hi-level güncel yazılım var mı acaba
hi-level uygun güncel yazılım var mı acaba bide netfilix nasıl yükleye biliriz
güncellemesini yapıp, tekrar servis menüsünün resmini çekip eklermisin.
core yükleme talimatı için: Tıklayınız
yokoono Çevrimiçi
Unfortunately I have nothing for the TV panel. I'm looking for more. Have you tried the repair software?
