Boatkiller
Hi. The apps are to old. Doesn't works.What is wrong with the TV?
To start, perform a factory reset: Menu, 4725, Diagnostic, Factory reset, OK.Hi. The apps are to old. Doesn't works.
Nothing had changed.To start, perform a factory reset: Menu, 4725, Diagnostic, Factory reset, OK.
You have authorization to download. Proceed at your own risk. It is installed using the sequence MENU 1505.Nothing had changed.
yukarıda kocaman uyarı var HER KONUNUN ALTINA AYNI MESAJI YAZMAYIN diye, yazdın eline ne geçti.!Başlık: Toshiba 49LL2A63DT (MB211) - beIN SPORTS / TOD Uygulaması Açılmıyor / Siyah Ekran
Merhabalar,
Toshiba 49LL2A63DT model TV'mde beIN SPORTS (TOD / beIN CONNECT) uygulamasını açmaya çalıştığımda sorun yaşıyorum (uygulama açılmıyor / siyah ekranda kalıyor).
Bu sorun için güncel çekirdek (core) yazılımı veya çözüm öneriniz var mıdır?
Cihaz Etiket Bilgileri:
Marka / Model: TOSHIBA 49LL2A63DT
Anakart (Şase): MB211 (10129035 2011 001628)
Seri No (SN): 8547960 001628
PNL (Panel Kodu): 23628135
VPAZ Kodu: 20275732
Destek olabilecek üyelere ve ustalara şimdiden teşekkür ederim.
Unfortunately, I don't have anything in my archive for the 17MB171 and the VES315WNGL-2D-N52 panel.Hello,
I need help with the correct full software or panel profile for:
Toshiba 32WA2063DG/2
Product Code: 10140199
Mainboard: 17MB171
Panel: VES315WNGL-2D-N52
Resolution: 1366x768 HD
The original problem was “storage space running out”.
After installing a compatible 17MB171 HD recovery firmware, the TV works normally, but the complete picture, Android logo, OSD and service menu are inverted 180 degrees.
There is no Flip/Mirror option in service menu 4725 and Panel Type cannot be changed.
Could you please provide the correct full USB software (upgrade_no_tvcertificate.pkg) or the correct panel/tvconfig/PQ profile for VES315WNGL-2D-N52?
Thank you very much.
This means that for the 17MB171, the panel profile cannot be saved using the "classic method."Hello yokoono,
Thank you for your reply.
I tried Downloadpq.mb171 with a FAT32 USB and ran USB Operations. The TV shows “Performing USB Operations…”, but unfortunately the folder remains empty.
Any idea what else I could try?
Thank you again.
Google translate:seg 43 ekran için yapacağım mb97 anakart ile ekstra yapmam gereken birşey var mı
