yokoono reis![]()
TELEFUNKEN
Model: D40F275N3
ART: 10094029
SN: 7248433400069
MB: 17MB82S
Hello friends! I need software for this TV. The terrestrial TV is not working. I want to reinstall the firmware.
yokoono reis![]()
TELEFUNKEN
Model: D40F275N3
ART: 10094029
SN: 7248433400069
MB: 17MB82S
TELEFUNKEN
Model: D40F275N3
ART: 10094029
SN: 7248433400069
MB: 17MB82S
1. In my archive it says this:
Yes, I'm sure. It was repaired before me. I think it was replaced. Matrix VES400UNDS-2D-N02.1. In my archive it says this:
Telefunken D40F275N3C main 17MB95M panel VES400UNDS-2D-N02. Are you sure it has 17MB82?
2. You don't receive cable programs?
3. Save the profile from tv and post it here. It is saved with a folder called READ (for 17MB82).
Before the repair, were T2 programs received?Yes, I'm sure. It was repaired before me. I think it was replaced. Matrix VES400UNDS-2D-N02.
T2 television does not work through the antenna. Does not find a signal.
Friend, I don't know if it worked before. I repaired the matrix in it and during diagnostics I saw that the T2 channels were not working. I will try this recovery file. Thank you very much for your help.Before the repair, were T2 programs received?
It is possible that 17MB82 does not know this. In my country we do not use T2.
If you want, you can find the recovery software here.
17MB82 is very old and I don't think it knows T2.Friend, I don't know if it worked before. I repaired the matrix in it and during diagnostics I saw that the T2 channels were not working. I will try this recovery file. Thank you very much for your help.
Linkteki ilk mesajı okuyunuz.Selamlar vestel smart tv için MB211 v.3 güncel yazılımı seçemedim.Destek olabilirmisiniz. (Youtube donma sorunu yaşıyorum)
En güncel sürüm yüklüMerhaba öncelikle kolay gelsin hocam cihazın yeni versiyon sürümü var mıdır yada stock yazılım yükleyip online güncelleme yapabilir miyiz
Aşağıdaki linkte cevap yazıldı.Merhaba,
Bende SEG marka bir televizyon var. Televizyon açılmıyor ve kırmızı ışık sürekli yanıp sönüyor.
SEG televizyonlarla ilgili konulara yazmak istedim ama maalesef hepsi kapalı görünüyor, o yüzden buraya yazıyorum.
Konuyla ilgili yardımcı olabilecek biri var mı?
Televizyonun fotoğrafını da aşağıya ekliyorum.
Teşekkür ederim.![]()
