toshiba 32DL933G
ralph65 Çevrimdışı
ralph65
27 Nis 2021
52
59
toshiba
32dl933g
vestel 17Ips19-3
MAIN 17MB62-2.5
display LTA320AN12
I have this toshiba led tv that does not turn on the leds. The voltage on the mos is 19 volts. Sometimes they turn on then after turning off the tv no the backlight leds turn on. What can i check?
istanbul Çevrimdışı
istanbul
7 Kas 2019
1,075
Toshiba 32dl933g / Vestel 17Ips19-3 / MAIN 17MB62-2.5 / Display LTA320AN12
Ledleri açmayan toshiba led televizyonum var. Mos üzerindeki voltaj 19 volttur. Bazen televizyonu kapattıktan sonra açılıyor, arka ışık ledleri yanmıyor. Neyi kontrol edebilirim?
ARIZA ( EVET / HAYIR )
Fişi takınca ışıklar yanmıyor ama ekrana toshiba yazısı geliyor tetikleyince led yanıp sönüyor
I don't know electronics
Google Translate
FAULT ( YES / NO )
When I plug it in, the lights do not come on, but the screen displays toshiba, and when I trigger it, the LED flashes.
17IPS19-5
d206 veya d207
d206 or d207
VESTEL 17IPS19-3 SCH​
istanbul Çevrimdışı
istanbul
7 Kas 2019
1,075
You can't fix it if you don't have knowledge of electronics. You must start the FORCED power supply by applying a positive voltage to the POWER ON, BL ON, DIM pins.
Thanks.
Subject owner ralph65 asking for help
toshiba
32dl933g
vestel 17Ips19-3
MAIN 17MB62-2.5
display LTA320AN12
ralph65 Çevrimdışı
ralph65
27 Nis 2021
52
59
Thanks.
the positive voltages at the POWER ON, BL ON pins are present 3.3 volts. sometimes the tv turns on regularly. can it be sw? i can't download usb firmware from the toshiba site. can you help me? thanks.
toshiba
32dl933g
vestel 17Ips19-3
MAIN 17MB62-2.5
display LTA320AN12
istanbul Çevrimdışı
istanbul
7 Kas 2019
1,075
Can you give a link to the Toshiba site software?
I asked forum friends.
Unfortunately, foreign TV software is not in my archive.
I don't know if it's on the website.
See check it out.
ATTENTION: you are responsible
NO SOFTWARE WARRANTY TO KNOW ?
Link :
