TELEFUNKEN T24TX114LPB 10088807
bubul
15 Eyl 2018
Hello,I have a vestel TV Mb-17mb82 I do the installation of the channels and after everything is completed successfully, on the screen appears No-Signal ,, is any suggestion for this case.Thnx
Tugi136
20 Nis 2020
500
30
B bubul
Hello
Cable tv?
Dish antenna?
I think your TV doesn't have an internal satellite receiver.
If you are using a satellite dish, return the television to the first installation, the television will turn off and on again, even if you use a single dish during the installation phase, make the diseqc settings and then search for channels.
If it is cable tv, return the TV to the first installation, the television will turn off and on again.
If the problem persists, you can try a software update to the TV.
V.1.3.7 Software link
Software update description
Unzip the software
Copy it into a blank flash memory.
Insert the flash memory into the USB port of the TV
Press and hold OK on the remote control
Plug the TV into the wall socket
Release the OK button when the led in front of the tv starts flashing fast.
The software will be installed in 2-3 minutes
Google Translate
