Replace the 24C32 memory with a new, empty one. It is very possible that the TV will start with an empty memory. The memory will be written by the processor. Turn on the TV and do a factory reset.
Google Translate
24C32 belleği yeni, boş bir bellekle değiştirin. TV'nin boş bir hafıza ile başlaması çok olasıdır. Bellek işlemci tarafından yazılacaktır. TV'yi açın ve fabrika ayarlarına sıfırlayın
THANKS
Replace the 24C32 memory with a new, free memory
Where is the 24C32 on the motherboard?
sub link and photo motherboard sub image .
I found this forum post, same as your recommendation!!!
buy and replace new product (empty)
24C32 EEPROM Integration - SMD 4Kx8 I2C/2-line Serial Eeprom
test the working status.
TEŞEKKÜRLER
24C32 ana kart üzerinde nerededir ?
alt link ve foto anakart alt görsel .
bu forum yazısını buldum , sizin tavsiyeniz ile aynı !!!
yeni ürün satın alıp değiştirmek ( boş )
24C32 EEPROM Entegresi - SMD 4Kx8 I2C/2-hat Seri Eeprom
test etmek çalışma durumu .
Google Translate
Hello to everyone! I have this tv with the following faulty, the remote control function is lost, the red stby led does not light anymore and if I turn it on from the physical button of the tv it starts again and when I change the channel from the tv buttons the tv stops, it does not stop when changing channels without the antenna cable. I've measured all voltages and it's OK, capacitors are fine. My suspicion is that the eeprom needs to be rewritten, it has 24c32, have you ever encountered such a flaw? I ask my colleagues who have a plan and possibly a litter box.
philips 22pfl3403/10 i couldn't find any serial in case
motherboard b3cbq1
I also attach some pictures with the TV
I'm waiting for ideas, thanks in advance
I think the motherboard series is 715t2849-1
try naked to see
Solved, replaced the eeprom with a blank factory reset and all is well!!
Google Translate
Herkese selam!
Aşağıdaki arızalı bu tv'ye sahibim, uzaktan kumanda fonksiyonu kaybolmuş, kırmızı stby led'i artık yanmıyor ve tv'nin fiziksel düğmesinden açarsam tekrar başlıyor ve tv butonlarından kanal değiştirdiğimde tv duruyor, anten kablosu olmadan kanal değiştirirken durmuyor. Tüm voltajları ölçtüm ve tamamlar, kapasitörler iyi. Benim şüphem eeprom'un yeniden yazılması gerektiği, 24c32'si var, hiç böyle bir kusurla karşılaştınız mı? Bir planı ve muhtemelen bir çöp kutusu olan meslektaşlarıma soruyorum.
philips 22pfl3403/10 kasada hiç seri bulamadım
anakart b3cbq1
Ayrıca TV ile bazı resimler ekliyorum
fikirleri bekliyorum şimdiden teşekkürler
Bence anakart serisi 715t2849-1
görmek için çıplak dene
Çözüldü, eeprom'u boş bir fabrika ayarlarına sıfırlama ile değiştirdi ve her şey yolunda !!!
