Panel yapılandırması 17MB130S ve VES650QNTL-2D-U1 gerektirir
yokoono Çevrimiçi
And on this main you rewrote the same software for the VES490QNEL panel.
I modified this too.
1. Format a stick with FAT32
2. Create a folder called pq on the stick
3. Unzip and put the 2 files in the folder
4. Turn on the TV, USB stick and type MENU 4725
5. Go to USB Operations and type OK on the remote control
6. Wait 10 seconds and exit the menu (return, back)
7. Turn off the TV from the remote control
8. Wait until the stby LED on the TV stops flashing
9. Unplug the TV and wait until the stby light goes out.
10. Take out the stick and turn on the TV.
If the image is not correct, repeat the operation
Use a stick with the smallest capacity possible (max. 16Gb).
DoubleM257
31 Ara 2025
12
I tried the pq files you provided me, unfortunately the image is still not good. Why is the panel “VES490QNEL” in the file “VESTEL_D1_Plus_TMG.bin” even though I have a “VES650QNTL-2D-U11” panel? Does this still need to be changed? Thanks for the help and have a good 2026.
EDIT: I just saw that the pq files you recently provided me are exactly the same as the ones I sent you. I think you sent me the wrong pq files.
DoubleM257
31 Ara 2025
12
I don't think it works that way. It's probably because I installed the mainboard from a 55 inch TV, but I have a 65 inch TV myself. I think there are configuration files in the NAND memory that you can't get to. If anyone has an idea why the picture is completely shifted and doesn't fit at all, please feel free to contact me.
Bu şekilde çalıştığını sanmıyorum. Bunun nedeni muhtemelen anakartı 55 inçlik bir TV'den takmış olmamdır ancak benim de 65 inçlik bir TV'm var. NAND belleğinde ulaşamayacağınız yapılandırma dosyaları olduğunu düşünüyorum. Resmin neden tamamen değiştiği ve hiç sığmadığı konusunda bir fikri olan varsa lütfen benimle iletişime geçmekten çekinmeyin.
