bu tersČo je správna treska pannelu (VES40???????????) ?.
VES400UNVS-N01 is cod panel ?.bu ters
çevirsem bilgi yok...
Ama yine ters bir bilgi çubuğu olan bir yazılımım da var, ama aynı zamanda YouTube'a da gidiyor
MB90_MB92_MB95_V376y
orijinalVES400UNVS-N01 is cod panel ?.
muhtemelen işe yaramayacakI have nothing in the archive for 17MB95M and VES395UNDC-2D-N01 panel.
If you know how, save the panel profile (pq profile) from the TV on the stick and see if it can be modified to return the image.
Evet bende var flaş programcısıYou have programmer for flash memory?.
Thank you very much...You have SPI software for flash memory. It is from Medion but has the same motherboard and panel. It is written with the programmer.
Pre flash pamäť máte softvér SPI. Je od spoločnosti Medion, ale má rovnakú základnú dosku a panel. Je napísaný s programátorom.
