17mb82S yazılımı
J Çevrimdışı
jony_jony0001
Yasaklı Üye
3 Mar 2021
48
17MB82S 10091351 23190133 391 39 ''
this is a software for usb tv, please, tv is not lit, only red led flashing, this is a vestel finlux tv,
Thanks
J Çevrimdışı
jony_jony0001
Yasaklı Üye
3 Mar 2021
48
Try.
[URL unfurl = "true"] [/ URL]
Do you know the installation procedure?
unfortunately NO, can you help me please
Try.
After a few tries I managed to start it up, is there any possibility to save the software to a USB stick currently on the TV, thank you very much
yokoono Çevrimiçi
73
1. Format a stick with FAT 32 (maximum 4Gb)
2. Unzip the rare file. Get a bin file
3. Copy the file directly to the stick
4. Unplug the 220v socket
5. Insert the stick into the USB
6. PRESS AND HOLD the OK key on the remote control (towards the TV)
7. Plug in the TV (220v)
8. The left LED flashes slowly and then quickly. When it flashes quickly RELEASE the OK KEY.
9. Wait for the update to finish. It may take over 5 minutes.
L.E. Only the profile on TV. Soft no.
J Çevrimdışı
jony_jony0001
Yasaklı Üye
3 Mar 2021
48
Try.
2. Unzip the rare file. Get a thousand file
5.Insert the stick into the USB
7.Plug in the TV (220v)
LE Only the profile on TV. Soft no.
What method can I save the old software to usb memory? Thanks
yokoono Çevrimiçi
73
You cannot save the software from the TV to the stick. You can only save some bin files but with some special programmers.
J Çevrimdışı
jony_jony0001
Yasaklı Üye
3 Mar 2021
48
When I know the software is installed, after 10 minutes the red LED blinks slowly.
I think now everything is fine, started from the remote and looks good. Thank you so much for all the help you do to be a happy man to be healthy.
I think it doesn't have a menu to search for TV channels :(
J Çevrimdışı
jony_jony0001
Yasaklı Üye
3 Mar 2021
48
What can I do to get TV shows ???? Help
jacabojacabo Çevrimdışı
jacabojacabo
18 May 2019
267
49
The TV did not turn on, only the red LED was on and flashing, after installing the above software, it no longer has a menu to search for TV channels
With the software installed, if the menu settings appear on the TV screen, the profile file is loaded.If the lighting is on and the menu settings are not available, we will try some suitable software tomorrow.If you have a spiflash programmer, there is a dump file, if you want, I will give.I'm a little tired I can help you tomorrow
J Çevrimdışı
jony_jony0001
Yasaklı Üye
3 Mar 2021
48
yarın mükemmel , bu yazılımı kurdum 17MB82 PANEL VES390UNDA-01.RAR İNDİR . İyi geceler
Menü görünüyor, ancak TV kanallarını arama seçeneği görünmüyor
