17mb211s panel yazilim
Durum
yokoono Çevrimiçi
Toshiba uzaktan kumandam var, kırmadım, sadece durdu. Hiçbir şeye rastlamadım, muhtemelen çeviriden anlaşılmadı, akımdan koptum
Pentru instalare iti trebuie telecomanda si tasta OK functionala. Procedura de instalare este trecuta pe forum de mii de ori.
corry
9 Eki 2022
6
Başka bir yazılım yüklemeyi denemedim, TV çalışmayı durdurdu
Her şey için teşekkürler, sen bir beyefendisin, Tanrı seni korusun
Pentru a instala it trebuie telecomanda si tasta OK functionala. Procedura de instalare este trecuta pe forum de mii de ori.
Nu am încercat să instalez niciun alt software, televizorul nu mai funcționează
Mulțumesc pentru tot, ești un domn, Dumnezeu să te binecuvânteze
Nu mai merge, s-a întâmplat ceva
mihai
23 Ocak 2023
8
57
Hi,
Maybe somebody can come with some ideas about following issue that I am facing with my " smart" JVC LT 40VF2L. The main board is the famous Vestel 17MB211S, screen VES395UNDC-2D-N12 (23477114). D ue to missing "wireless connection" from the Menu I tried to reinstall the full software using an USB, as I have seen on different sites; the process was started ok but somehow was "frozen" and after 24 hours I removed the USB(because the red led did not stop blinking). I was trying to turn on the TV but nothing happened(the red led is blinking continuously but the TV is not switching on) neither with remote or using the joystick from the back the TV panel. There is something that can be done under the above mentioned circumstances? Thanks in advance
yokoono Çevrimiçi
what ,
I have for 17MB211
mihai
23 Ocak 2023
8
57
Thanks, but the issue is the TV is not taken any command now. I was trying to repeat the software installation procedure but no chance; TV is not turning on (red led is blinking). How can I proceed to reinstall the software?
yokoono Çevrimiçi
You need a bin for the flash memory. It is written with a programmer. Unfortunately, I do not have.
mihai
23 Ocak 2023
8
57
other question: I found main board 17MB211S(not from JVC) with screen no VES395UNDC-2D-N12 but not having that number 23477114 as my TV has. Can you tell me if it match to my TV?
Thanks
yokoono Çevrimiçi
There may be differences between the 2 motherboards. A specialist can tell you if it can be compatible. Call a service. Not all TVs can be fixed with a stick.
Durum
