:mrian_sma' Alıntı:I have downloaded the archive but it contains a file named upgrade_mb130.bin witch is the same with the MB130 firmware
is it safe to install?
Ado' Alıntı:mrian_sma' Alıntı:I have downloaded the archive but it contains a file named upgrade_mb130.bin witch is the same with the MB130 firmware
hello, the core software is a single file with a .bin extension. The current full writing will upgrade without touching. It is safe and genuine software.
uvar:
mrian_sma' Alıntı:Ado' Alıntı:hello, the core software is a single file with a .bin extension. The current full writing will upgrade without touching. It is safe and genuine software.
Using MENU 1505 method it gives software update faileduvar:
this is the tv
:Ado' Alıntı:mrian_sma' Alıntı:Using MENU 1505 method it gives software update faileduvar:
this is the tv
full yöntemi ile de yükleyebilirsiniz:
You can also upload with full method:
uvar: ...blinking stanby led
uvar:mrian_sma' Alıntı:Ado' Alıntı:full yöntemi ile de yükleyebilirsiniz:
now the tv is deaduvar: ...blinking stanby led
uvar:
It's a Polaroid p32d300fp serial 7840164 702234Ado' Alıntı:mrian_sma' Alıntı:now the tv is deaduvar: ...blinking stanby led
uvar:
Sometimes the concept is confusing because we try to negotiate with google translation. I ask in the name of understanding, do you upload mb 110 motherboard mb130? if so, it is quite normal that it collapsed. you should write your TV serial number. Let's see what we can do to save.
