Merhaba arkadaşlar 2 tane 4k Film indirmiştim televizyonda görüntü testi yapmak için.HDD ile Usb girişinden taktım.Bir tanesinde sıkıntı çıkmadı fakat diğerinde görüntü gelmiyor sadece ses geliyor.Sebebi ne olabilir.Görüntü gelmeyen de aşağıdakı panelde ekstra olarak HDR yazıyordu onunla alakalı olabilir mi ?
Video bu özelliklere sahip
General
Unique ID : 221553219000191637100958681139832954703 (0xA6AD990E52699BA9B733150D0ECC1F4F)
Complete name : E:\Planet.Earth.II.S01E05.Grasslands.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT.mkv
Format : Matroska
Format version : Version 4
File size : 16.3 GiB
Duration : 51 min 21 s
Overall bit rate mode : Variable
Overall bit rate : 45.4 Mb/s
Encoded date : UTC 2017-10-18 10:23:09
Writing application : mkvmerge v16.0.0 ('Protest') 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.8
Cover : Yes
Attachments : cover.jpg / cover_land.jpg / small_cover.jpg / small_cover_land.jpg
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 43.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.216
Stream size : 15.4 GiB (95%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color pri : R: x=0.000000 y=0.000000, G: x=0.000000 y=0.000000, B: x=0.000000 y=0.000000, White point: x=0.000000 y=0.000000
Mastering display luminance : min: 0.0000 cd/m2, max: 0 cd/m2
Audio
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 2 330 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 16 bits
Compression mode : Lossless
Stream size : 856 MiB (5%)
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 50 min 43 s
Bit rate : 25.7 kb/s
Count of elements : 718
Stream size : 9.33 MiB (0%)
Title : English-PGS
Language : English
Default : Yes
Forced : No
TV BU
General
Format : Matroska
Cover : Yes
Video
Format : HEVC
Color space : YUV
Bit depth : 10 bits
Default : Yes
Forced : No
Audio
Format : DTS XLL
Codec ID : A_DTS
Bit depth : 16 bits
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Muxing mode : zlib
Title : English-PGS
Language : English
Default : Yes
Forced : No
