VESTEL 65O9900 OLED TV ÖZELLİKLERİ
On mb130S model, picture DV settings are locked too on TV ?
And for mb230 too ?
mb130E and mb130S are very close (same?) and I see that mb130S has HDR and DV compatibility activated (true) but Movie Sense off (False)
So, if mb130S has no Movie Sense (or Tru Flow) on his DV BRIGHT mode, I don't understand why when I set Movie Sense off (False) on my swprofile
my mb130E activates it on DV BRIGHT mode...:hmm
For mb230 there are more information at Picture and PicturesVsSourceVSMode (New Pixellence setting, more folders...)
@EXcomZkko @teraspy
Do you think it's possible to active pixellence on swprofile (softpix...) for OLED panel and it will work (better) ?
Or it's just for LED ?
Thanks
And for mb230 too ?
On MB130 DV settings are locked yes, on MB230 they are available to fool around.
Which I find as an asshole move on companies end.
It's incomprehensible...
I try to found how have access to advanced settings in swprofile to modify.
I'm sure that is a way to change what we want.
@EXcomZkko @teraspy
Thanks
I can say that, just try and see yourself. There is a demo options will be appear on Video settings page. It will cut the screen to half vertically and shows the result side by side.
Just follow the instruction here https://tavsiyeforumu.com/konu/hi-l...xellence-ve-winks-ozelligini-aktif-etme.6226/
and there will be demo option on picture settings of TV ?
Thanks again
With update 5.34.1.4 I succeeded to access to advanced settings for DV mode.
All locked too, but now I can see that Tru Flow option is set to LOW on DV Bright mode.
So, I will try to found a way to change advanced settings mode by mode for all.
Thanks again
Yes, it should be named as Pixellance Demo or equivalent of Toshiba brand.
Actually looks like there are some "unknown" presets exist. But none of them looks like DV Bright mode. Because picture setting parameters are different than DV Bright mode (If I'm not mistaken)
I think DV mode (Dark and Bright) presets are B82D0C6B and 9929628F folders in PictureVsSourceVsMode for Hdmi, USB or DTV.
I don't know wich is Dark or Bright, but when you look settings it's sure that they are DV mode.
But there's not advanced settigns like Dynamic Contrast or Tru Flow in this section but just basic settings.
I was thinking.
How Vestel or Toshiba can they lock settings ?
WIth toolbox we can see how we can add or remove an option (by change True or False value).
But how lock all option (basic and advanced) on selected mode ?
If they can lock, we can unlock.
Maybe there is an "unknown" option on swprofile to modify ?
I was thinking.
Toolbox is a reversed engineered software. It may not shows all options or swprofile file may not responsible for advanced video settings tab. Actually we can't be sure about this. :bilmiyom
Forum enternasyonal olmuş vay be ?
I was thinking.
As far as I know, those settings are stored in eprom, and we can not modify eprom. Maybe we can somehow enable the menus on DV. Please share any findings. I would love to try the modified profiles out.
Maybe you're right my friends.
But we have access to many many options with swprofile (DV and HDR support, Picure Mode, Movie Sense, Pixellence, Noise Reduction, Energy Saving Mode...)
and even Smart app option like Prime, Netflix ...
I hope that we can modify what we want.
Brightness difference between Dolby Vision Dark (and HDR) and DV Bright mode and Tru Flow activation only for this mode can't be write on eprom.
Why ? Because before 5.34.1.4 update, I can't have access to advanced settings.
Now, I can. All are locked expect ZOOM MODE.
But maybe I'm wrong I'm not a specialist
