,If the motherboard is 17MB95M you have profile here:
TV YAZILIM İLE İLGİLİ VESTEL EU YA MESAJ ATMISTIM ONLAR DA BANA BİR YAZILIM GÖNDERDİ ANCAK KENDİLERİ DE GARNTİ OLMAYACAGINI SÖYLUYOR. TECRÜBELİ USTALARIMIN PROGRAMI İNCELEYABİLİRLERMİ FAYDASI OLUR BELKİ BEN UPDATE YAPMADIM SİZLERDEN ONAY BEKLİYORUM GÖNDERİLEN MESAJ
We provide you with this software without warranty or warranty! Since this software has been developed and tested for the current devices, we cannot rule out complications in older devices.
The update should only use the update data provided by the manufacturer.
Updates may only be made in accordance with the instructions.
We assume no responsibility should data loss occur during the upgrade.
Guide:
1. Please copy the files below to an empty formatted USB stick (do not create subfolders)
• mb90_en.bin
• mboot_spi.bin
• usb_auto_update._A1txt
2. Turn off the TV and disconnect it from the mains
3. Connect the stick to USB-1
4. Press and hold the OK button on the remote control while reconnecting the device to the power supply.
Note: Hold down the OK button until the standby LED starts flashing (fast)
5. When the standby LED flashes quickly release the OK button on the remote control.
The software update starts automatically.
6. The software update is over when the standby LED stops flashing
We would be very grateful if the update helped you.
If you have any questions, please call 089-211 29 000 from Mo-Fr between 8a.m. and 6 p.m.
This request is made by us under the processing number 716762.
Please always include these processing numbers.
@yokoono (what do you think about this programme.. )
@By_Trol
@jacabojacabo ustadlar sizde bakarmısınız yokoono ustanın gönderdiği program ıle aynımı
