Toshiba 32l5660ea Full Software
elrefaey
29 Kas 2023
10
49
P.lease send Full Software for Toshiba 32l5660ea
Motherboard 17MB110
Panel VES315WNDS-2D-N13
Thanx in advance
Master yokoono yokoono can help you. I tagged him. He will see the correspondence when he logs into the forum.
Google translate
elrefaey
29 Kas 2023
10
49
Should i have to change name of files or not?
if the TV was off before it is unpluged then when plugging it
the green led flashes for 2 seconds
and backlight turns on then off again
and green led become off and the red led is on
I still pressing OK from remote while the sequence above is running and nothing happens
Also i tried to unplug TV while it is Turned ON then insert the flash and press OK from remote then Plug the TV
The turninig on sequence happens without start loading software
I have RT809H programmer, can i use it to flash the software?
elrefaey
29 Kas 2023
10
49
Try at your own risk. If the remote control no longer works, use a programmable one.
