Teletech LED22906 (17MB82S) – CI+ authentication issue after firmware v1.3.7 (credentials question)
adbastrag
14 Kas 2025
Hello everyone,
I have a Teletech LED22906 (17MB82S) TV on which I installed v1.3.7 full firmware package (MB82 10094700 27355764 v137).
I saw that it is the newest firmware for this chassis, it looks and works well overall, but it has serious issue: no longer succeeds in authenticating CI+ cable provider DIGI Romania (the authentication process is very slow, reaches 80%-90% and returns to 4%).
Before installing this firmware was using VEM141HE_40220 SVN153064 version, on which I had no problems with CI+ authentication (CI+ authentication worked perfectly).
Analysis of extracted files PRODUCTION_CREDENTIALS.bin and hdcpkey.bin shows that v1.3.7 FULL writes blank/invalid:
In these conditions and because I do not have advanced knowledge of the internal firmware structure, I would like to ask for your opinion:
Would it be safe and technically correct to: write PRODUCTION_CREDENTIALS_VEM141HE.bin and hdcpkey_VEM141HE.bin (both files from VEM141HE_40220 SVN153064 version)
over PRODUCTION_CREDENTIALS_v1.3.7_FULL.bin and hdcpkey_v1.3.7_FULL.bin (both files from v1.3.7 version) in order to restore CI+ authentication, while keeping firmware v1.3.7?
Are there known alternative solutions to keep v1.3.7 firmware + working CI+, without change firmware version?
Any experience, confirmation, or technical insight is welcome.
Thank you very much!
Herkese merhaba,
Teletech LED22906 (Vestel 17MB82S)
model bir televizyonum var ve bu cihaza v1.3.7 FULL firmware paketini (MB82 10094700 27355764 v137) yükledim.
Bu sürüm, bu şasi için en yeni firmware gibi görünüyor. Genel olarak iyi çalışıyor ve arayüzü de güzel, ancak ciddi bir sorun var: CI+ kimlik doğrulaması (DIGI Romanya kablo operatörü) artık düzgün çalışmıyor.
Kimlik doğrulama işlemi çok yavaş ilerliyor, yaklaşık %80–90 seviyesine ulaşıyor ve ardından tekrar %4’e düşerek başarısız oluyor.
Bu firmware’den önce VEM141HE_4.0.220 (SVN153064) sürümünü kullanıyordum ve bu sürümde CI+ sorunsuz şekilde çalışıyordu.
Çıkarılan dosyaların analizine göre v1.3.7 FULL, PRODUCTION_CREDENTIALS.bin and hdcpkey.bin, aşağıdaki dosyalara boş/geçersiz veri yazıyor: PRODUCTION_CREDENTIALS.bin and hdcpkey.bin,
Bu koşullarda ve firmware’in iç yapısı hakkında ileri düzey bilgim olmadığı için sizlere danışmak istiyorum:
Aşağıdaki dosyaları PRODUCTION_CREDENTIALS_VEM141HE.bin ve hdcpkey_VEM141HE.bin (VEM141HE_4.0.220 SVN153064 sürümünden alınmış)
v1.3.7 firmware’indeki PRODUCTION_CREDENTIALS_v1.3.7_FULL.bin ve hdcpkey_v1.3.7_FULL.bin dosyalarının üzerine yazarak, v1.3.7 firmware’ini koruyup CI+ kimlik doğrulamasını geri kazanmak teknik olarak güvenli ve doğru olur mu?
Ayrıca, firmware sürümünü düşürmeden, v1.3.7 + çalışan CI+ kombinasyonunu korumak için bilinen başka çözümler var mı?
Deneyimlerinizi, doğrulamalarınızı veya teknik görüşlerinizi paylaşırsanız çok memnun olurum.
Teşekkür ederim.
televizyonun ürün kodu 10089584, cihazınıza uygun olmayan 10094700 ürün kodu yazılımı yüklemişsiniz. Yaşadığınız sorun sebebi bu olabilir.
adbastrag
14 Kas 2025
Thanks for the answer!
On this TV model. I had firmware versions v0.7.8a (factory default), then upgrade to v0.8.4 and later upgrade to v1.3.7.
Yes I knew that the product codes did not match but I really liked the menu design (similar to v0.8.4) and other additional options and that is why I decided to keep this firmware version v1.3.7 (which I thought was the same as the one above, but this was a full version) and try to find a solution for CI+ authentication.
If I don't succeed, I will return to the old firmware version.
For now I am still looking for solutions and waiting for suggestions.
Thank you !
Cevap için teşekkürler!
Bu TV modelinde, önce v0.7.8a (fabrika varsayılanı) yazılım sürümünü kullandım, ardından v0.8.4'e ve sonra da v1.3.7'ye yükselttim.
Evet, ürün kodlarının eşleşmediğini biliyordum, ancak menü tasarımını (v0.8.4'e benzer) ve diğer ek seçenekleri gerçekten beğendim, bu yüzden bu v1.3.7 yazılım sürümünü (yukarıdakiyle aynı olduğunu düşünmüştüm, ancak bu tam bir sürümdü) saklamaya ve CI+ kimlik doğrulaması için bir çözüm bulmaya karar verdim.
Başarılı olamazsam, eski yazılım sürümüne geri döneceğim.
Şimdilik, hala çözümler arıyorum ve öneriler bekliyorum.
Teşekkür ederim.
