- 23 Kas 2017
- 20,960
Silverstone adreslenebilir RGB aydınlatmalı işlemci soğutucusu 237 TL!
Görsellik ve soğutma isteyenler düşünebilir.
Model No. | SST-AR12-RGB |
Application | Intel LGA 115x/1200/1366/2011/2066 AMD Socket AM4/AM3/AM2/FM2/FM1 |
Material | Copper heat pipes with aluminum fins (HDC) |
Heat Pipe Type | Ø6mm heat-pipe x 4 |
Fan blade size | 120mm x 120mm x 25mm |
Fan speed | 700 ~ 2200RPM |
Air Flow (CFM) | 68.9 CFM |
Air pressure | 2.7mm/H2O |
Noise | 9 ~ 29 dBA |
Rated Voltage | 12V |
Bearing | Hydraulic bearing |
Life Expectance (hrs) | 40,000 hours |
Connectors | 4 pin PWM + 4 pin RGB header (+12V) |
Net weight | 632g |
Dimension | 128mm (W) x 154mm (H) x 75mm (D) 5.04" (W) x 6.06" (H) x 2.95" (D) |
Giriş yap veya üye ol.
