Maybe something can be found if you also post the panel code: VES550 ??????.
Or type MENU and 4725 and put the picture.
here is picture, if you need more info about my tv let me know please.
my regards
I will make the necessary arrangementI can't access the picture. Post here.
here is picture again Mr yokoono
tanks for reply Mr Sota@digsat2,
Hello, use the image codes as the system gives you.
(your pictures will not be visible if you change them)
I have edited your message.
@fikoloji , @TEKNOWESTtanks for reply Mr Sota
but i need new firmware or software for my toshiba smrt tv because the apps is not loading and crashes any help please.
my regards
yes i have update the software and i download it from here for toshiba tv there is only one file v 2.45.10.0 only nothing else ,i need new software for my apps as i told you is crash and freeze , anyway thaks for your help , my regardsSo you have the 17MB120 motherboard and the VES550QNDL-2D-U11 panel. The installed software version is 2.45.10.0 not 2.41.6.0 as you wrote in the first post. For what you have in the TV I have no newer software. Neither does the manufacturer. Searching for:
If you want to try another software you have it here. You do so at your own risk.
ok i will take a risk just to make sure is this software compatible with toshiba 55 inch 4k tv and will fix netflix ssiptv apps ?2.45.12.1 or 2.45.27.0
Update at your own risk.
last night at 23.30 uk time , all i know was toshiba mb120 core update so i toke a risk , and every think was ok except for netflix , ss iptv still no luck same problem i thinks i need full software including all apps to be update it ,thank again and i hope not given you a headache .I do not know. Nor does Toshiba publish software on the site.
When did you upgrade to version 2.45.10.0 did you know it's for your TV?
