recherche firmware usb pour vestel 17mb120
digsat2
25 Ocak 2020
28
59
Maybe something can be found if you also post the panel code: VES550 ??????.
Or type MENU and 4725 and put the picture.
here is picture, if you need more info about my tv let me know please.
my regards
D digsat2 ,
Hello, use the image codes as the system gives you.
(your pictures will not be visible if you change them)
I have edited your message.
yokoono Çevrimdışı
So you have the 17MB120 motherboard and the VES550QNDL-2D-U11 panel. The installed software version is 2.45.10.0 not 2.41.6.0 as you wrote in the first post. For what you have in the TV I have no newer software. Neither does the manufacturer. Searching for:
If you want to try another software you have it here. You do so at your own risk.
Thanks Sota.
I apologize for the offtopic.
I want to express my condolences to the survivors of the victims of the serious earthquake that took place in Turkey.
digsat2
25 Ocak 2020
28
59
D digsat2,
tanks for reply Mr Sota
but i need new firmware or software for my toshiba smrt tv because the apps is not loading and crashes any help please.
my regards
digsat2
25 Ocak 2020
28
59
yes i have update the software and i download it from here for toshiba tv there is only one file v 2.45.10.0 only nothing else ,i need new software for my apps as i told you is crash and freeze , anyway thaks for your help , my regards
yokoono Çevrimdışı
I do not know. Nor does Toshiba publish software on the site.
When did you upgrade to version 2.45.10.0 did you know it's for your TV?
digsat2
25 Ocak 2020
28
59
last night at 23.30 uk time , all i know was toshiba mb120 core update so i toke a risk , and every think was ok except for netflix , ss iptv still no luck same problem i thinks i need full software including all apps to be update it ,thank again and i hope not given you a headache .
regards
